Swapping el34's for 6l6GC's?
Hi. I was wondering if the El34's in the Trainwreck could be swapped with 6L6GC's? I am a bit disappointed in the TW when it comes to overdrive, a bit too much Marshall to my liking. Or is there any other parts that could be tested to get the gain going a bit?
Re: Swapping el34's for 6l6GC's?
Yes you can swap 6L6's in and see what that sounds like. Just reset the bias.
Current production KT77s work well.
Best .. Ian
Best .. Ian
I tried swapping a pair of 6l6'gc's in. Didn't change the overall sound of the amp.
I wonder what else could be an essential part of the amps sound. Compared to my 50w and 100w Dumble, the sound is very English.
I have never tried K77, but I will now.
If swap to 6L6 wasn't a notable change for you then going to KT77 likely also prove much the same. The appeal to me is they sit in between with some characteristics of each, plus a bit more headroom. Worth the experiment perhaps.
Best .. Ian
This is the problem with people assuming EL34 = british sound, 6L6 = american sound. The circuit around the tubes is way more important than the tube type.
Which circuit are you using? They're probably going to always have a bit of a marshall flavor due to the Marshall style 'cold clipper' in the liverpool and express. The express is more Marshally because it basically has a Marshall tonestack and PI along with the cold clipper.
