Hope everyone is safe and sound these days, practising, soldering, and making the best out of these unprecedented times.
Last December, I found online an old beat up Pine Electronic Tube Amp, a bargain! I bought it and thought I could re-use the PT and OT and build a Tweedle Dee.
I set up a layout and added a few things based on Rob Robinette's experiences, and Charlie WIlson, ToneMercury, M. Fowler, Tony Albany and Marcus' testimonies, tweaking their own builds. Thanks Charlie Wilson for sharing this fantastic build with the ampgarage community, it is a real cool and fun one to build !
Changes from Charlie Wilson's schematic:
-chan1 would be a straight Dumble stage : 22k grid stopper 220k on the plate and 2.2k/5uf on the cathode
-Add a cascading/parallel switch that allows chan1 to cascade into chan2
-add a passive FX loop
-add a Pre PI Master Volume
-470R 3W grid stoppers
-add a Negative feedback switch ( V2A cap bypass/Off/56k NFB)
Used Orange Drops 6PS caps on this build, and I am preparing another build with 715 Orange drops caps only (I want to hear the difference
As the Pine amp had no rectification tube and was using diode rectification, I re-used the same topology, so I can keep voltages on par with what these were initially (B+1 was 364 v.).
I had fun putting together everything in a small 6 x 10 x 2 hammond Chassis, my goal was to make the amp as compact as possible. I need a Grab and Go amp that I can use with a few pedals, though this would be it!
First impressions on the build :
- soldering and assembling in such a tight space is a real challenge. It is even more difficult to service the amp if you need to do some maintenance (had replaced the 1M Local NFB with the MV initially and found out the hard way that it is difficult to debug a new layout once all the cable are hooked and that you trimmed these the exact length
Sonically, I must say this built goes beyond my expectations, it is really great, roars like beast. Agreed it is a bit bassy on a 2x12, and I want to try it with 10s to hear the difference. I am planning on ordering a celestion rocket 50 to try what Mr Dumble had in mind. I would say it is ideal for anyone playing Blues. I love the early breakup and compression to the sound.
A few remarks :
Chan 1, on it own is too bassy to be used as is
Chan 2 is much more versatile and interesting
Love the versatility of the feedback switch that allows this beast to breath hard (Chan2 + 0 NFB) or roar when I cascade chan1 into chan2 and bypass the V2A cap)
I though I would have trouble with the passive FX loop, but it appears it works extremely well. I am plugging a TC electronic reverb + TC mini-delay, and it sounds glorious!
PT is getting pretty hot after an hour or so... still can touch it though.
6V6 are getting really hot, like I cannot let my fingers on, else I get burnt
I need to build the head cab for this one, but I am in love already!
A few pics :
Voltages :
Mains : 120 VAC
B+1 : 364,1VDC
B+2 : 359.6 VDC
B+3 : 317.5 VDC
B+4 : 300 VDC
V1 12AX7 (probably an old Sovtek)
V1A plate : 172
V1A cathode : 1.28
V1B plate : 186
V1B cathode : 1.138
V2 12AX7 (probably an old Sovtek)
V2A plate : 208
V2A cathode : 1.638
PI
V2B plate : 264,2
V2B cathode : 42.2 <= this one is almost twice as high than what CW had on his schematic...
V3 6V6
plate : 352.3
screen : 352
cathode : -21.48
V4 6V6
plate : 352.1
screen : 352.9
cathode : -21.42
 I love those small chassis, I've not been able to find them in the UK though.
 I love those small chassis, I've not been able to find them in the UK though. .... a lovely light show then ......bang.
