talbany wrote: ↑Mon Feb 17, 2020 12:59 pm
Bombacaototal wrote: ↑Mon Feb 17, 2020 12:49 pm
I added everything to the schematic and all doubts and questions and missing values in green. I think it will make it easier for all
YES! Perfect thank you!
 Generally when you have a part in question your asking about? put it where you think it goes highlight it
10K along with a
 ? That way we are both looking at the same thing. Will cross it with what I have
  BTW.The 10K looks OK
    1. I am not showing a .1 on the Dry amp on any of my schematics??
    2.The only 1meg's I am showing are on each side of of the .01 like you have it. I am not an expert on trem's perhaps someone else might know what a  Trem- Osc control resistor is?
  3.The 220k is the grid resistor for the input to the mixer AFAIK
Noted with thanks Tony. I made some further amendments to the schematic taking your suggestion into account. I coloured the resistors (10K, 30K) on the bias network at the PI as this is where I think they are but not 100% sure. I left the comment on the missing 47K.
Regarding the 10K on the Reverb driver the question was more relating to the LNFB. So I added another LNFB in green. I am not sure if the LNFB is before or after the 10K as I have seen HAD amps taking both approaches.
As far as the .1uF on the Pentode, it is indeed there, both on the parts list and also on the blurry gutshot. Electron makes mention about it too  on his thread about the pentode amp. I am happy to put together some "evidence" shots if you would like.
The third 1 MEG on the tremolo is indeed puzzling. The 270K I coloured in green as this is where I think it is. Fender uses 390K there.
As far as topology, I think the entrance of the reverb is as per my black line. Most of the SSS amps use a 5751 on the driver circuit and having the AT7 there will already compensate for the difference in gain between a 12AX7 triode and the EF86 wired as triode. Also it has the matching LNFB and grid to the Pentode, which would indicate that this position makes sense
EDIT: Updated schematic further down the thread
