First of all I’d like to say a big thanks to the forum for all the knowledge that’s been shared here that has allowed me to build an Express. Particular thanks to RJ who provided me with the kit to built it.
It’s taken a while but is finally built.
I followed the lamp limiter/start up procedure in the build guide and everything was looking good! Voltages all checked out.
Bias was a little off out the box with plate dissipation coming out at around 12.5 Watts using the 1ohm resistor method.
As I made an adjustment to the bias voltage I measured voltage drop over the 1ohm resistor and, when I went to check the plate voltage on v5 again and, as I touched pin 3 got a sparkler show that continued till I powered down (I guess a couple of seconds)
I’ve removed the flyback diodes and they test ok.
Can I ask the hive mind here what the trouble shooting procedure would be? Or if you’ve any idea what could have caused the sparking?
This is not my first amp but it is my first full size Express.
Some pics for you all.
