another Express type build
5 others liked this
Re: another Express type build
Puzzled.
Nice cabs Marcus. Cream tolex will look great! You saw mine already in my thread in the Speaker Cabinet forum section.
I used the Sand nubtex tolex and thanks to a friends request I matched it with the Oxblood grill cloth with white piping and thought it matched nicely.
I see you painted the inside before applying the tolex, I learned that lesson the hard way LOL.
Cheers
Guy
Cheers
Guy
Sorry Marcus, to clutter up your thread, but Martins comment had me laughing
Also, nice attention to detail, beautiful cabinet work!
- norburybrook
Martins comment had us all laughing here
I'm going over to a friends this morning to do the bevel on the Walnut face panel, I didn't want to chance doing it badly, then back to tolexing
M
- norburybrook
3 others liked this
Well I planed the Walnut into shape went through 60,80,120,240,400 grit sand papers then applied sealer. Then polished with Tru oil, which is gun stock oil.
Did my Tolexing and grill cloth piping etc.
Few little things left to do after i return from a much needed holiday.
M
M
- pompeiisneaks
- Site Admin
Looks great! I like how the diamond grill cloth and white piping go with the tolex.
- norburybrook
thanks guys, I'm pleased with it. The front panel especially. That was a bit nerve racking taking a plane to that
M
M
- norburybrook
well I spent the day tweaking and setting things up/burn in as it's going to be delivered tomorrow to it's new owner.
I fitted a switch to switch between 0.05 and 0.002uF when in fast mode, I've labelled it as 'Fast mode bass boost' , glued the bright caps together/to the pot so less chance of vibrations. Decided as it's a part tolex cab i should make a back panel so have done that.
i still don't know what the cab will sound like until we get the Celestion Classic lead 80 in tomorrow. Amp is sounding Killer through my 1x12 lead 80 cab.
Will report back with some pics of the hand over and testing.
M
M
Looks like a "keeper" to me.
Best .. Ian
Best .. Ian
The cabinet and speaker cab is really something, something you would want sitting in you living room...lol
Marcus how does the MV sound in your Express? Does the cut control work well with it?
- norburybrook
The MV works great, nothing much Happens for the first half of the sweep, maybe it's because it's a linear pot, it does take the edge off the volume though in a good way. Once past midway it really starts to work, and out of all the master volume types this one is the best IMHO an this amp, it's the LarMar type 2 the dual 250k pot replacing the grid leak resistors. Obviously it won't make the amp great at bedroom levels but for taming the amp a little it's great.
The cut control is also very useful and a simple addition, they're very bright amps so the cut just takes the edge off if needed, I've added a bypass switch so it can be taken out of circuit.
It's a great sounding amp this one, better than the first one i built, it has a chime/bite that i don't remember the first one having and it cleans up better too on the gtr volume. I'm tempted to make one for myself now, really enjoyed playing this today. With my dumble 1x12 classic lead 80 cab and this amp it's a powerful little rig that does a really nice SRV chime/grit thing in a very small package.
M
Thanks for the info.... I sold my Express I built a couple of years ago.
I could only run my amp at 1 or 2 because where I lived at the time
I keep thinking I should build another too. Maybe I will. I still have a Pacific 6.6k OT and an express faceplate that I got from RJ
That has David Root’s name on it....
peace
peace
- norburybrook
Put the fast slow split plate switch on, makes it a lot more more usable along with the master volume.joeboo88 wrote: ↑Mon Aug 19, 2019 6:49 pm Thanks for the info.... I sold my Express I built a couple of years ago.
peace
M
Marcus,norburybrook wrote: ↑Mon Aug 19, 2019 2:56 pm
M
maybe the Orange Drops used now make the better sound. I remember your first express where you installed the Sozos. Maybe the right iron also.
I built an express with 150s Mallorys. Later I changed it to 6PS Orange Drops. Much better sound.
Anyway, great work.
Did you test the amp with EV12L? If so, which is better? The Celestion Classic lead 80 or the EV12L?
Groove
