talbany wrote: ↑Fri Jul 19, 2019 9:37 pm
Fred
A few thoughts. Check the (bias) current draw on the tubes on both Tube and SS rectifier settings and make sure they don't red plate when you go to the SS setting.
The PT tubes used to red plate when I was running all tubes on empty (no board to draw current).
I have not checked since, but the smell of the PT tube red plating has disappeared
I will take measures to make sure there is no problem on that side too.
If you don't ground out the channel you are not using the signal will bleed through the mixers and ghost note on you..
If you already know this carry on!
At first I was running the two channels feeding the D-lator without mixing resistors, and the amp was oscillating, especially if I did try to shut down one channel (all pots at 0). As soon as I would open the knobs just a bit, the oscillation would go away.. I put in 220k mixer resistors, but it seems like the tweed channel still has to much output. Marcus and Erwin suggested that I tried to lower the output of the tweed channel with either another resistor in serie after the V2b coupling cap, and before the mixer resistors.
It is amazing how two channels output can be that different! I checked on the Charlie Wilson's Tweedle Dee layout and voltages and output measures do fit with what I get. but then there is a 1meg resistor before the signals enter the PI..
I added a 220k 2w resistor after the coupling cap of V2b for the tweed channel, and it made a little improvement, but not enough. The channel still has some distortion going on.
I will give a try at the 470k for both mixing resistors and see how it goes.
I though about using another relay in order to ground the signal of the channel that is not being used instead of using mixer resistors.
It would be synchronized with the input relay.
I know @Sluckey is using a switch on his dual marshall amp to ground the unused signal but only after the first stage of amplification.
Would this avenue allow me to tweek the two channels output independently?
Thanks for the help and suggestions!
Fred.
