Reverb Circuit Hum
Vox and Hiwatt Discussion
earl2
Re: Reverb Circuit Hum
Post by earl2 »
When I built this amp (no reverb) I definitely had to add a grid leak resistor on the triode before the phase inverter. Without it the amp made all kinds of howling noises. The original schematic doesn`t show one which always seemed strange to me. Don`t know if you added one. Mine also benefited a lot from a grid stopper on the phase inverter.
Post by Stevem »
Yes it sure does, sorry!
mwaller
Post by mwaller »
Roe wrote: Wed Jan 30, 2019 8:18 am have you tried a 100k reverb pot ala fender?
I have not, but I definitely will try this! I believe I have a 100K linear pot in my parts bin. Did Fender use a linear or audio taper?
mwaller
Post by mwaller »
earl2 wrote: Wed Jan 30, 2019 8:21 am When I built this amp (no reverb) I definitely had to add a grid leak resistor on the triode before the phase inverter. Without it the amp made all kinds of howling noises. The original schematic doesn`t show one which always seemed strange to me. Don`t know if you added one. Mine also benefited a lot from a grid stopper on the phase inverter.
You're correct - OS/71 version of the schematic has an error in this regard. The 470K resistor (R29) is supposed to go between GND and the grid of V4b. That is how I built it. Likewise, the 100k resistor (R30) is supposed to go between GND and the grid of V3b.
There is a corrected version of the schematic labeled OS/026 which is included in the limited edition of the book Vox Amplifiers: The JMI Years
I don't own the book, but I've seen the schematic. It is much easier to interpret.
mwaller
Post by mwaller »
I tried this tonight... Unfortunately, no difference. Possibly even worse buzzing than before. I also shielded the grid wire to V4 gain stage, but that didn't seem to make a difference either.
I measured ac ripple in my power supply. The first node has 5.5v. The rest are more like 0.1 - 0.3. Is that typical?
earl2
Post by earl2 »
I didn`t know about that revised schematic. Had to make my own. In any case thanks for confirming what I worked out back then by a combination of logic and trial & error !
Looking at the Ampeg schematic it should have been obvious really. What threw me for a while were the photos of several originals which look for all the world as if they are indeed wired as shown in that original schematic.
Whats the primary impedance of that output transformer you`re using? I often wondered if Vox used the usual 8k or 6.3k as in the AC15.
Good luck with the hum. If I have any fresh ideas I`ll give you a shout.
Post by Stevem »
Well if 5.5 volts is true then your tube socket is bleeding heater voltage thru it, as that could be the only reason I can justify!
What I would do to confirm this is to disconnect all the wires from that socket but for the 2 heater wires and the test to see if you still read that 5.5 volts on any of the other socket terminals.
sluckey
Post by sluckey »
It's very normal for the first node to have 5v or more ac ripple with a typical cap input filter.
mwaller
Post by mwaller »
earl2 wrote: Thu Jan 31, 2019 9:16 am
The OS/026 schematic shows an 8K-ohm output transformer. I'm using a Mercury Magnetics transformer that was designed for this amp. I assume it has an 8k primary, but I haven't verified.
mwaller
Post by mwaller »
sluckey wrote: Thu Jan 31, 2019 2:05 pm
Could a leaky filter cap cause hum that isn't reflected in the RMS ripple measurement taken with my DMM?
The reverb circuit has always been a bit troublesome, but I seem to recall a time when the amp was otherwise quiet with reverb off. I even tested it with the higher efficiency speaker, and I don't recall hearing much hum.
Now I hear hum all the time, which suggests that something has changed. I've tried to put the circuit back to how it was originally before any updates, and I still have hum. I'm very suspicious of the ARS filter caps. I typically use F&T, but I decided to try the ARS because the Marshall guys seem to like them.
Perhaps I have a bad cap?!
mwaller
Post by mwaller »
As I pulled the filter caps in anticipation of installing new ones tomorrow, I realized that my grounding scheme may be to blame for some of the hum. My original layout connected all the filter cap grounds to a lug near the inputs. When I install new caps, I believe I should connect the ground of the 32uF caps somewhere close to the power tubes. The 16uF caps should be grounded near the inputs as before. Does that sound right?
Roe
Post by Roe »
I recommend multistar grounding with one star grouding for each power supply node. Keep the distance between the different grounding points at least 2"
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
earl2
Post by earl2 »
mwaller wrote: Fri Feb 01, 2019 6:49 am As I pulled the filter caps in anticipation of installing new ones tomorrow, I realized that my grounding scheme may be to blame for some of the hum. My original layout connected all the filter cap grounds to a lug near the inputs. When I install new caps, I believe I should connect the ground of the 32uF caps somewhere close to the power tubes. The 16uF caps should be grounded near the inputs as before. Does that sound right?
Yes I did it exactly like that and mine doesn`t hum. Not to say that`s your problem though.
mwaller
Post by mwaller »
Roe wrote: Fri Feb 01, 2019 8:01 am I recommend multistar grounding with one star grouding for each power supply node. Keep the distance between the different grounding points at least 2"
Would it be best to ground the power tube filter caps near the speaker jacks? Alternatively, I could simply ground it to the same location where the center taps are connected next to the power transformer. Thoughts?
earl2
Post by earl2 »
I ground them where the center taps go next to the power transformer and everything preamp at the other end near the input jack. Never had any problems doing it like that.
