Merlin's Ultra High Gain preamp
Marshall Amp Discussion
Re: Merlin's Ultra High Gain preamp
Checking voltages and then will upload my voltage chart for the Merlin Ultra High Gain circuit into JCM800 power amp.
I will also get Steve Stine to make a video of both the Fowler HRP and this Merlin amp, mean while I uploaded a video of his playing. He is a great guitar player and teacher.
https://www.youtube.com/watch?v=HM_3SGbSlME
My voltage chart for this Merlin Ultra High Gain preamp circuit into Marshall JCM800 2204 type power amp.
Merlin Ultra High Gain Voltage Chart.pdf
In it's cab now.
Maybe it's just me but I don't hear anything when I use the noise reduction switch two diodes.
pompeiisneaks
Site Admin
Post by pompeiisneaks »
You may not have much noise :D
Phil, it is really a high gain sucker so I reduced v1 to 5751 and plan on tube rolling some more 12AY7 in V1 & V2 and maybe this amp would like a 12AT7 phase inverter! :)
pompeiisneaks
Site Admin
Very cool. I really would love to hear some samples of the amp!
Guys like the Merlin Ultra High Gain circuit it's crazy high gain.
I like my other AFD circuit better.
I get a lot of oscillation so will be back inside the amp to try cure that. Might have to punch a new preamp tube hole further over plus gain stage grid resister.
Also, wondering if my layout is correct for that noise reduction diode circuit, I hear no difference when switching.
ChopSauce
Post by ChopSauce »
Sorry for being late, but I think I remember Merlin wrote a few lines about the minimal distance between pre-amp tubes in his book. Maybe that had to do with his experiences with this pre-amp?
I knew that too, but I wanted to use a standard punched chassis readily available to all.
Davidg
Post by Davidg »
Did u by chance get time to do any soundclips or videos of this amp? Really anxious to hear it ! Your amps always look and sound great. 👍
If Hendrix had lived would he have been as good as EDDIE? (Shaver that is)
No I didn't but I will in future.
Home remodeling right now, bought a cheap house for my oldest son.
frankdrebin
Post by frankdrebin »
M Fowler wrote: Sun Jun 24, 2018 2:22 pm Thanks Steve we need one of your cool circuit pages on this.
Changed layout to reflect discussion.
Remember guys I am terrible at Visio as you can see.
I took the color bands off the ones I don't have in my library rather then change the colors I got to get going so maybe later I can add back in color bands.
the 4th stage cathode resistor is 820 ohms,there is an errata page on Merlin's site.
820R in place of the 1k8 and 10uf cathode 4th gain stage?
EDIT: In fig. 14.7 on page 260, the cathode bias resistor of the fourth stage should be 820 ohms not 1.8k. The anode voltage should be approximately 140V not 192V.
I finally got around to changing out the bypass resistor and removed the 10uf cap all together.
The amp still has plenty of high gain and I took it over to the local guitar shop for people to play around with along with my 50w Hot Rod Plexi.
