Best attenuator
Re: Best attenuator
that IS my first attenuator and these are my monkey feet holding it rofl
That jack on the back would start a million threads if it belonged to Van Halen
hitchcaster
Re: Best attenuator
Post by hitchcaster »
heres another build with pics
http://valvestorm.com/MultiLoadBox
Ron Jinks
Re: Best attenuator
Post by Ron Jinks »
I am liking the Weber 50 watt Mini Mass on the Express that I built. And so does everyone that hears it.
Variac versus VVR?
Post by Mark »
I have wondered about the whole VVR versus the Variac thing.
The Variac does lower filament voltage which must effect the electrons emitted from the cathode to some degree.
The VVR does cause scratchiness to the guitars volume pot (typically higher value pots more than lower value pots), but surely the Variac must have this problem as well.
I find new Variacs are quite expensive, I don't think the VVR is that expensive.
Putting VVR into a build can be a pain due to heat sinking the FET and
Finding a good position for the voltage control.
Other thoughts on this matter?
Yours Sincerely
Mark Abbott
brewdude
Re: Best attenuator
Post by brewdude »
you can alleviate the guitar pot scratches by inserting a capacitor between the input jack and the first tube's grid.
Re: Best attenuator
Variac operates just like a wire to the amp.. with a big knob...
I never run one without selecting a metered voltage and setting a mark on the range that I reproduce the same voltage returning to that mark. All metered. If it's to compensate for the expected voltage on a vintage amp I set that voltage and run it. If it's about dumping voltage I check it as above and turn the knob down until I am happy.
I don't care about electron quantity. I use it as a master volume. It gets softer sounding as the voltage drops. The amp reacts pretty much like it has full voltage all the way down until it stops. Not running 450-500v on output tubes makes them last most of forever. The small tubes never seemed to mind much either. I still have a couple Marshalls running the original xf2s and they just keep going, and going, and going. :)
Some things don't like a variac lowered more than they like higher than called for wall voltage. Depending on Fender amp type, the trem is going to do something freaky or nothing.
Marshalls love it until the tubes go dark. I don't run anything with channel switching or any relays. That could be a problem.
MHProd
Re: Best attenuator
Post by MHProd »
Best Attenuator: Torpedo ReLoad (or attenuators using the same technology).
Re: Best attenuator
Post by Mark »
The Torpedo ReLoad has a lot of features beyond an attenuator. That is a lot of added expense to a guy just wanting an attenuator.
Yours Sincerely
Mark Abbott
kanderson70
Re: Variac versus VVR?
Post by kanderson70 »
Mark wrote: Wed Oct 10, 2018 6:37 pm I have wondered about the whole VVR versus the Variac thing.
Not sure if this ever got answered, but I've used both a VVR and a variac. The VVR did cause scratchy pots so I yanked it out. The variac.... did not cause any scratchiness. I think I grabbed my old vintage 60s variac off of ebay for $60 (of course I see the same one listed by others for $199...guess I got lucky).
RockinRocket
Re: Best attenuator
Post by RockinRocket »
Educate me.
Why would the VVR make the guitars pots scratchy?
Colossal
Re: Best attenuator
Post by Colossal »
RockinRocket wrote: Mon Nov 12, 2018 5:00 am Educate me.
If you regulate youre preamp stages, when the plate voltages get low enough, you get DC on your guitar's volume pot. Normally, when installing a VVR, a cap is used to block any DC and the grid leak resistor for that stage is moved after the cap.
Re: Best attenuator
Specifically, it’s due to the onset of grid current, which will flow through the guitar volume pot to ground unless blocked by a capacitor.
Re: Best attenuator
This is why I am furious about the electric company charging ME for the use of MY local ground potential.
Re: Best attenuator
Post by Mark »
The scratchiness is easily fixed with an adequate sized poly cap.
In fact the scratchiness is fairly common on Trainwreck Rocket amps. I have found it happens on Gibsons more than Fenders, I suspect the 500K Gibson pot versus the 250K Fender pot is the reason. Selecting a "good" valve helps but that ends up being a short term fix.
I don't understand how the scratchiness can occur with VVR and not occur with a Variac. Maybe the low heater voltage has something to do with it or perhaps the Variac isn't turned down as low as the VVR.
Yours Sincerely
Mark Abbott
Winder
Re: Best attenuator
Post by Winder »
Unless you require a "vintage" Staco variac, these work just fine. I have three of them. Bump that $52 to $59 and get a digital readout!!!
https://www.circuitspecialists.com/vari ... 05kva.html
