#124 Questions
Bombacaototal
Re: #124 Questions
Post by Bombacaototal »
norburybrook wrote: Tue Sep 18, 2018 2:53 pm because it's generally a lot easier as there's plenty of space there :D
it's actually coming 'from' the power board to V1 then on to the FET. All the B+ come from the power board and onto their respective valves.
MC
Got It! Many thanks :)
pompeiisneaks
Site Admin
Re: #124 Questions
Post by pompeiisneaks »
I believe another reason you want it at the end of the chain, is that's where it used to be when there was a FET there, if you put the 150k earlier in the chain voltages across the amp will differ, and therefore not be the same as the original, it will drop them wherever you put it in the chain by some amount. You want it doing the same thing as dropping for the FET only at that point in the chain.
Bombacaototal
Re: #124 Questions
pompeiisneaks wrote: Tue Sep 18, 2018 3:51 pm I believe another reason you want it at the end of the chain, is that's where it used to be when there was a FET there, if you put the 150k earlier in the chain voltages across the amp will differ, and therefore not be the same as the original, it will drop them wherever you put it in the chain by some amount. You want it doing the same thing as dropping for the FET only at that point in the chain.
Hi Phil, I think electronically the junction of the two 100K plates, the end of the 2.2K dropping resistor and the end of the 150K plate of the FET are the same point. What I was thinking is the 150K on the board like the attached below (yellow circle - red lines), instead of adding it by the 2.2K at the Sprague Supply Cap
pompeiisneaks
Site Admin
Re: #124 Questions
Yes those are all the same logical point in the circuit, sorry misunderstood the explanation earlier. That should be perfect.
Guitarman18
Re: #124 Questions
Post by Guitarman18 »
pompeiisneaks wrote: Tue Sep 18, 2018 6:21 pm Yes those are all the same logical point in the circuit, sorry misunderstood the explanation earlier. That should be perfect.
+1 - Two Rock did that on their Jet........
'Beauty is in the ear of the beholder'
Bombacaototal
Re: #124 Questions
No worries Phil and thanks for helping out!
Thanks for sharing guitarman. They went for 2W as well. Any reason not to use a 1/2W like the FET plate would?
Re: #124 Questions
Yes, a good reason- a 1/2W will burn up. 2W is good.
norburybrook
Re: #124 Questions
Post by norburybrook »
That looks ugly to me. Putting it on the power board mages more sense to me from an ergonomic point of view.
Martin, any electrical engineering reason why it's better the way Two rock did it?
M
Sent from my Nexus 6 using Tapatalk
Bombacaototal
Re: #124 Questions
Thanks Martin, will get some 2W. Is Two rock using Koa Speer?
Guitarman18
Re: #124 Questions
norburybrook wrote: Tue Sep 18, 2018 8:23 pm
M
I agree Marcus. It looks like a band aid repair - not what HAD would do, I bet.
Paul.
norburybrook
Re: #124 Questions
Bombacaototal wrote: Tue Sep 18, 2018 7:50 pm No worries Phil and thanks for helping out!
Raphael,
it's NOT a plate resistor it's a dropping string resistor hence it neds to be a 2W, if you look at the electrolytic cap and the 150k resistor mounted in the right hand chassis of #102/124 ODS they're part of the power section it's just that on earlier Dumble's there wasn't room on the power board. As the caps are now smaller and we have a great board layout by Martin, all those caps and resistors are now on one board, so putting the FET dropping string resistor on the end of the dropping string makes sense if you know you're not using a FET.
that's why that two rock looks poor to me, it's a bodge.
M
Bombacaototal
Re: #124 Questions
norburybrook wrote: Wed Sep 19, 2018 8:15 am
Raphael,
M
Thanks Marcus, I will follow your advice as far as placement of the 150K and noted with thanks regarding it being a dropping
norburybrook
Re: #124 Questions
cool, I'm no expert though.
basically it's the difference between putting at one end of a wire or the other :D
you can also use that resistor value to change your other plate voltages too as it affects everything down the chain.
MC
Bombacaototal
Re: #124 Questions
sluckey wrote: Sun Sep 16, 2018 3:45 pm I like to use a standoff turret to support grid stoppers. This one has a base with 4-40 threads. Simply screws onto the socket screw.
Sluckey, I want to give it a go at your suggestion and I was wondering if you by any chance have handy the part of the turret standoff. I am struggling to find it in mouser. Many thanks!
norburybrook
Re: #124 Questions
as long as the thread works with your screws any standoff will work :D I'd just replace the screw and use a regular standoff you use for mounting boards here in the UK as it will be a metric thread, getting/using US threads is a PIA here. Computer motherboards use standoffs too so are easy to find.
M
