fired up this morning and low voltage on the filter caps?
Re: fired up this morning and low voltage on the filter caps?
Replacing the balance resistors is a start, but I don't understand why nothing seems to happen until it's switched off standby.
He followed the Ceriatone layout and the STBY switch is between the rectifier diodes and the reservoir cap stack.
- skyripper2
ok so in standby mode with the 60 watt limiter bulb i am getting.....
bias -50vdc on one and -37vdc on the other lug of the pot
on the standby switch one side seeing 392vdc and the other 0v
the relay is at 16.32v going in and 11.88v feeding the relays.
eat,sleep,build amp.........
- skyripper2
also when in standby and checking voltages ,the sixty watt bulb was very dim.
The standby has been relocated to after the reservoir caps now or no, and that's in standby? Can you switch it to play and does the limiter stay dim?
- skyripper2
is it possible that the choke is wired backwards? as this is my first build i am learning.
The light bulb limiter is just a quick check to see if you have a short circuit. When you turn the power on, the bulb should be bright momentarily, then go dim right away. If that’s what you’re seeing, go ahead and plug the amp straight in to your electrical outlet and proceed with voltage checks.
- pompeiisneaks
- Site Admin
This is not possible, chokes don't have a direction.skyripper2 wrote: ↑Fri Jun 29, 2018 8:05 pm is it possible that the choke is wired backwards? as this is my first build i am learning.
- skyripper2
not sure what you are asking. if i take it out of standby the light is bright and stays bright and there does not seem to have very much voltage on the lug of the standby switch . one side see's lots the other does not. i believe my standby is before the caps.martin manning wrote: ↑Fri Jun 29, 2018 8:01 pm The standby has been relocated to after the reservoir caps now or no, and that's in standby? Can you switch it to play and does the limiter stay dim?
That says there is a lot of current draw after the standby. Have you replaced the 220Ω resistors with either 220k or 270k?
- pompeiisneaks
- Site Admin
Thismartin manning wrote: ↑Fri Jun 29, 2018 8:17 pm That says there is a lot of current draw after the standby. Have you replaced the 220Ω resistors with either 220k or 270k?
DO. NOT. POWER. ON. AGAIN. UNTIL. YOU. REPLACE. THESE.
- skyripper2
Thanks Phil i figured as much but had to ask.pompeiisneaks wrote: ↑Fri Jun 29, 2018 8:07 pmThis is not possible, chokes don't have a direction.skyripper2 wrote: ↑Fri Jun 29, 2018 8:05 pm is it possible that the choke is wired backwards? as this is my first build i am learning.
- skyripper2
well off to see my dentist .
this will have to wait . and again thanks for trying to help me get her going.
- skyripper2
pompeiisneaks wrote: ↑Fri Jun 29, 2018 8:18 pmThismartin manning wrote: ↑Fri Jun 29, 2018 8:17 pm That says there is a lot of current draw after the standby. Have you replaced the 220Ω resistors with either 220k or 270k?
thanks Phil i won't
- skyripper2
well i survived the dentist.
so after seeing that i used the wrong resistors on my filter caps . I figured i had better check my main board and everything else and see if i used wrong values elsewhere. so i took the layout and started marking things using windows paint!!!!! green dots (good) and red dots (wrong needs changing) to simplify things . I found a local electronics tech who says he's got what i need so this next week i can go get the right values from him and try again. opening the drawing up in windows paint made my life a lot easier .
