new build choice, 2nd gen 50w
norburybrook
Re: new build choice, 2nd gen 50w
Post by norburybrook »
pompeiisneaks wrote: Tue Mar 27, 2018 9:51 pm Actually this ones in the UK for you:
http://www.cdguitars.co.uk/slide-switch ... 1918-p.asp
same price range but shipping is likely better/faster/cheaper.
Argh....you guys....I really should get the red ones shouldn't I?
M
dariez75
Post by dariez75 »
Where I can buy this kind and others dumble chassis?
modman
Post by modman »
dariez75 wrote: Wed Mar 28, 2018 11:40 am Where I can buy this kind and others dumble chassis?
http://amplifiednation.com/chassis/ ?
https://tubeamparchive.com/memberlist.p ... ile&u=9801
dariez75
Post by dariez75 »
thanks modman but I was searching the 2nd generatio chassis, the same used in first pictures of the thread
dariez75
Post by dariez75 »
Wonderful, I hope they ship fast
norburybrook
It was about 10 days IIRC.
There are no mounting points so yo will have to work out how to mount it to your chassis. I think I'm going to go with Cage nuts, or perhaps weld nuts on the bottom of the chassis ,fender style.
Marcus
norburybrook
Well I couldn't resist. I've ordered the red switches.
I've nearby finished the main board. I think it looks suitably 'retro' in '70's brown :D shame I haven't got a load of NOS components.
Progress.
Tomorrow I need to make a mounting plate as my PT is too small for the holes.Image
Sent from my Nexus 6 using Tapatalk
norburybrook
So, the red switches arrived. I'm glad I've done it. Looks great. Just waiting for a pilot light to finish off the front. Aesthetically I'm not sure about the cliff jack....I know it will work reliably though.
MImage
Looks fantastic! Where did the knobs come from?
norburybrook
Flea Bay
https://www.ebay.com/itm/Ridged-Control ... 2749.l2649
Martin,
In the interests of NOT using a cliff jack. How would I wire this up for the FET? the on eon the layout as double connections on the outside and a single in the middle, this has the opposite.
M
pompeiisneaks
Site Admin
Post by pompeiisneaks »
For the fet you need those special switching jacks that can do dual level of switching between them to setup the ground correctly. I had to reread the schematic like 10x to realize just any jack wouldn't work. I had to search and find the right jack for mine on the forums and found the following:
https://tubeamparchive.com/viewtopic.php?f=4&t=16905
it shows a nice layout posted by structo that shows what exactly needs connecting too. I got the kobiconn jack from mouser linked by krinkle at the last post of the first page.
Matt J
Post by Matt J »
Curious.... Has anyone ever tried to build a 2nd or 3rd gen ODS without the rock/jazz switch, so that it is just wired straight as if the rock position were engaged?
dbeasley
Post by dbeasley »
Matt J wrote:Curious.... Has anyone ever tried to build a 2nd or 3rd gen ODS without the rock/jazz switch, so that it is just wired straight as if the rock position were engaged?
Yes, Ive done this on a few builds. I personally never use the jazz setting so it does save a small bit of complexity. You are essentially eliminating the 100K/.05 cap on the Jazz/Rock switch. At that point you don't even need a switch (duh lol) and can free up space for a PAB/Mid boost toggle - which I find to be more useful.
Sent from my Moto G (4) using Tapatalk
Matt, I drew up a couple of nothing-but-rock layouts for Marcus a while ago, and they are posted here somewhere.
Marcus, for the FET you need a jack with an additional switch contact on the sleeve or ring contact, or one with an isolated switch like a 13E.
