Can someone confirm or correct this list, please?
Non-HRM Classiq EQ :    3rd generation Period Correct ODS 50W,   #40
https://tubeamparchive.com/viewtopic.php?f=5&t=5986
Non-HRM Skyliner  EQ low plate:   #124      ( #102 Robben Ford's prior to skyliner EQ)
https://tubeamparchive.com/viewtopic.php?f=5&t=5719
Non-HRM  Skyliner EQ  high plate:   #183,   #102  (Robben Ford's after the skyliner EQ was added)
https://tubeamparchive.com/viewtopic.php?f=5&t=13095
https://tubeamparchive.com/viewtopic.php?f=5&t=12873
HRM  Skyliner EQ:    #101
https://tubeamparchive.com/viewtopic.php?f=5&t=5481
https://tubeamparchive.com/download/fil ... &mode=view
Blues Master:   100 HRM in the Blues Master style
https://tubeamparchive.com/viewtopic.php?f=5&t=3344
With respect, 10thtx
													Dumble styles & corresponding amp #'s
Re: Dumble styles & corresponding amp #'s
Good idea. I would use nomenclature like this:  ODS(-R) - <plate R config> - < clean tonestack> - <OD tonestack> - <derivative>
-R added to ODS indicates reverb
Plate R configurations are Low-Plate (all 100k) or High-Plate (220k/150k)
Clean Tonestacks are Classic or Skyline, and might have Deep or PAB, but AFAIK Skyline always has PAB.
OD tonestack is HRM, only if applicable (avoid using "Non-HRM"). BTW, I think HRM is "Hot-Rod Marshall.
Derivative would be Bluesmaster, e.g.
Maybe someone else can comment on this "system," i.e. does it cover the majority of cases... Max?
