anyopne built a Allen amps Hot Fudge with nuts?
dcribbs1412
Re: anyopne built a Allen amps Hot Fudge with nuts?
Post by dcribbs1412 »
Nice looking build Mark
very Dumbly lookin cab
really dig the combonation of blonde tolex wood and vox cloth
is the wood mahogany?
D
TUBEDUDE wrote:I forgot to ask, is that an aftermarket power strip, or did it come with the bench?
Strip was separate from the bench. Got the strip at Menards a DIY store like Lowe's popular up North.
dcribbs1412 wrote:Nice looking build Mark
D
Yes the little wood strip is Mahogany. Very early Amplified Nation cab built for 2.5" chassis and mine was only 2" so added the wood strip.
roseblood11
Post by roseblood11 »
Does anybody have a schematic (and maybe a layout) for the Hot Fudge with Nuts?
Yes
tubeswell
Post by tubeswell »
Its a relatively simple fixed bias single channel amp with bias vary trem:
  • 5AR4 rectifier
  • 2 x 6L6 (or 2 x 6V6) fixed bias output stage
  • Brown vibrolux (6G11a) bias vary trem powered by a 12AX7 LFO with CF buffer,
  • 6G3 brown deluxe 12AX7 LTP inverter (820R bias, 6k8 tail, and 100P local plate feedback),
  • NFB 56k/1k5 divider going to the LTP tail. This is variable with a 500k pot wired as a variable resistor in series with the 56k (Instead of using a 500k pot to vary the NFB, a switch to short the 1k5 would be simpler - e.g. a 1M tone pot with a toggle push-pull SPST switch.),
  • Brown 6G2 Princeton input channel (with a tweed princeton tone control and volume between V1a and V1b). V1b cathode is fully bypassed and V1a has a switchable 0.68uF/22uF cathode bypass. (Again, you could use a 1M pot with a toggle push-pull SPST switch for the volume pot to activate the Ck switching)
  • There is a 15k supply dropper between V1b and V1a, a 22k supply dropper between the LTP and V1b supply nodes, a 10k supply dropper between the screen supply node and the LTP node, and an HT choke filter between the output tube plate and the screen supply nodes.
roseblood11
M Fowler wrote: Wed Oct 18, 2017 11:18 amYes
Thanx! :D
