How do you go about deciding what parameters you want for a transformer, both PT and OT?
Some are obvious, such as whether the OT has the impedence taps you want (4, 8, 16 ohms). Or if you have a rectifier, you want a PT with power, heater, -and- rectifier outputs.
Especially, for:
PT- Voltage and current. I imagine the voltage is driven by what power tubes you use and attendant max voltage needed, and the current by how much you're driving (power and preamp)? Is it crucial to have center tap on heater?
OT - Watts and Primary impedence? For watts, imagine it's based on Power tube type (and number). Impedence, no clue
Edited to add: Also looking for rough numeric parameters, if possible. Ex - range of PT voltages based on driving EL-34s, 6L6, etc.
Thanks all.
