Erwin the bottom wires on the switches all go to ground, the top wires go to the footswitch, if I swap them round aren't I just reversing the position of 'manual or pedal, i.e I'd be just turning the switch upside down not reversing the LED behaviour '?erwin_ve wrote: ↑Wed Jun 28, 2017 4:10 pm Lol that pesky relay thing.
The relay connections that are on the layout are the ones are ok.
The wiring for the backpanel switches are the ones that need to be reversed. Middle lugs stay the Same. Bottom and top wires are reversed, so the footswitch leds got ground connection when they are supposed to be on. Check if you can follow this thought. It should be right, but I'm doing this by what's in top of my mind and don't have a schem. in front.
My footswitch is wired like this with the exception of the 0.1uf caps, I don't have anything there.
Marcus
