DRRI Master Volume
				Bombacaototal
DRRI Master Volume
I am curious of people's opinions about adding a master volume to a Deluxe Reverb reissue. I read that a Post Phase Inverter would be best but was wondering if anyone ever tried a dumble like master volume, which is Pre Phase inverter
Re: DRRI Master Volume
Why do want a master volume on a 18 watt RMS amp, less overall volume, or more preamp stage distortion?
				Bombacaototal
Less overall volume for home practiceStevem wrote:Why do want a master volume on a 18 watt RMS amp, less overall volume, or more preamp stage distortion?
Ideally I would put it at max when playing live which would be same as not having it
H
You want low wattage for the home, unplug the reverb tank drive cable and hook up a 8 ohm speaker and like magic you then have a 1  watt amp!
Don't screw around with a MV , as they always mess with the tone of the amp to one degree or another .
				Bombacaototal
Thanks for the advice everyone
