5F6-A reverb idea/question
Fender Amp Discussion
Luthierwnc
Post by Luthierwnc »
I'm toying with the winter project and was thinking of a '59 Bassman. Reverb helps. I've got some schematics with different out and insertion points but was wondering how folks here think a passive loop after the treble pot would work with my Neunaber Wet. It's a nice sounding device in an active loop and would save a lot of effort if it would work with just the line level signal. I could put it in front of the amp too but I like time-based effects to be on the outward-bound side of the tone stack.
Thanks, Skip
Re: 5F6-A reverb idea/question
Post by Stevem »
well you would be driving the out board effect with the needed low impeadance off of the cathode, but I am not sure how the tone will be?
Luthierwnc
The one-tube reverb circuits on the Dumble side work a bit like that.
Attached is another possibility, Thanks, sh
10thTx
Post by 10thTx »
Skip,
I've done quite a few one tube reverbs and I've gotten to where I prefer an active FX loop. I've done this type of arrangement on 4 different amps and have liked it.
The V2a CF and tone stack acts as the FX send and the V2b acts as the FX return. Makes for a nice master volume also. I have this exact arrangement on my current D'Mars ODS 5879 for the clean channel.
Just and idea to consider along with others.
With respect, 10thtx :wink:
pdf64
Post by pdf64 »
10thTx, a 22k load on the 5F6A tonestack seems to have a big effect on tone control ranges (try it in TSC)? A dropper resistor before the 22k would help a lot, eg 470k - 22k potential divider.
Luthierwnc
I see the possibilities. Hope you're well, BTW. Is the Send pot a trimmer? That's where I'd put the Neunaber. AT 12 VDC it handles line-levels. If it bogs down I might put the trimmer on the send entrance and run it straight into the recovery with a 220k grid-leak.
This will be a head serving either 8 or 4 ohm cabs so I made a couple changes for the configuration. Bias will depend on whether the PT has a dedicated tap.
Looks like the little caps on either side of V2b are knocking down some hash. I used the stock 270p's on "D" amps but never experimented past that. I've thrown a 1meg resistor across single volume versions of 2-pot CF entrances to replicate the ground reference of the originals. Sometimes dimed is too hot but the 5751 might fix that.
I threw a "Purist" switch in as a 3PDT mini but there is probably a better way if I think about it more. Not sure it won't pop wickedly with the phase change but I've certainly had more expensive failures -- and then I still have a switch -- maybe a 10 uf bypass cap on V1b K.
Also attached is my version of the T-Lite 5879 OD we kicked around a couple years ago.
Cheers, sh
10thTx
Post by 10thTx »
There isn't really a send pot per say just a 22k resistor to ground. Originally I had a 250ka pot there where the 22k now is but found this simpler and more to my liking tone wise. And I found I wasn't adjusting the 250k send pot using the delays and reverb pedals.
It has a return pot and level pot.
pdf64
Post by pdf64 »
OK, but as Luthierwnc has added a true bypass switch, it should be bourne in mind that the frequency response from the tone stack may be rather different, fx loop bypassed cf fx loop engaged.
Luthierwnc
Has anyone tried pulling the signal off one of the plates and fed it back in at the PI with a blend pot (like the Hoffman tweed reverb circuit except further upstream)?
Here's an old musing on the cathodyne Fenders of yore but with the dual pentode/triode circuit in my first schematic. It's mostly on here to show how the circuit bleeds back into the mix early in the circuit. sh
10thTx
Post by 10thTx »
I like that idea of the blend pot with the reverb! That's a cool idea.
with respect, 10thtx
Luthierwnc
Maybe something like this, sh
