6G3 Post PIMV
Fender Amp Discussion
LedZepp007
6G3 Post PIMV
Post by LedZepp007 »
Quick question. Would the attached edits work to be an effective PPIMV in the 6G3 circuit? Love the circuit, but would need manageable volume.
Thanks!
robrob
Re: 6G3 Post PIMV
Post by robrob »
Yes, that's a Trainwreck Type 3 Master Volume and it's what I put in my 5F6A Bassman and it works great. It mixes the two phase inverter output signals together which kills the signal, like mixing matter and anti-matter. Sort of. :lol:
[img:300:630]https://robrobinette.com/images/Guitar/ ... Volume.png[/img]
LedZepp007
Re: 6G3 Post PIMV
Thanks!
I wonder if a pot would actually fit next to the jack in the typical 6G3 chassis. The MV might have to be fitted to the back, though I'd prefer the front. I don't have much use for the Low gain Bright input.
pdf64
Re: 6G3 Post PIMV
Post by pdf64 »
That's asking for trouble, eg oscillation.
It may work ok, but far better to put it away from input circuits, eg ground switch, ext speaker holes.
LedZepp007
Re: 6G3 Post PIMV
pdf64 wrote:That's asking for trouble, eg oscillation.
Shielded cable would be used.
robrob
Re: 6G3 Post PIMV
Post by robrob »
You can also just twist the two MV wires together since they're 180 out of phase it works the same way as twisting the heater wires to reduce rf transmission.
