Corking bottom plate
gahult
Post by gahult »
I was going to go and find a store for adhesive backed cork. But, I found my roll of cork I purchased for previous builds. Inside of the roll I found a roll of "Heat-n-bond" iron on fabric adhesive I "removed" :twisted: from the wife's sewing possibles and hide in the roll of cork.
Figured I might as well try it instead of the messy contact glue I used before.
Here is what I did.
1 I cut the cork using the bottom plate as a template and a piece of "Heatnbond" bigger than the cork.
2. Decided to trim it a little closer to the size of the cork as it may be easier to work with.
3. I ironed it to the cork, paper side up.
4. I trimmed it to the size of the cork.
5. Show the bottom plate on top of the cork...the paper will be removed from the adhesive and a hot iron is used on top of the bottom plate to adhere the cork. Then I just use the rolling cutter to trim it to the same size as the bottom plate.
Good to go, no mess.
Gary
In the 60's people took acid to make the world weird. Now the world is weird , and they take Prozac to make it normal.
Ron Worley
Re: Corking bottom plate
Post by Ron Worley »
The stuff I use is adhesive backed already, really easy to use. Got it at Michael's or Hobby Lobby, don't remember which.
Ron
Nice job Gary.
Like Ron I got the adhesive back cork from Lowe's cabinet section used to line kitchen drawers. :)
gahult
Post by gahult »
I didn't think to look at Lowes.
The Hobby Lobby and Micheal's are about half an hour away.
Just tried what I had on hand from years ago. :)
When I run out I will certainly try the adhesive backed cork as it would seam to be a better way to go.
Gary
