picked up a hammond AO-35
stretch2011
What should I make? It runs two 12ax7's, two 6bq5's, and a 5y3.
First thoughts are ac15, 18watt Marshall, Dr. Z Carmen ghea,low powered rocket.
Re: picked up a hammond AO-35
You can do a Spitfire or a Songwriter, except don't refer to it as a Songwriter. A Ghia started out as a AO-35, so there are a number of good layout options with that platform.
BLT
patrick620
I have built a few Brown Note Lite IIb amps out of them. Myself and many others liked them.
guitar-rocker
Swap out the 5y3 for a 5v4 and build a Superlite TMB.
Run the first ax7 for the input in parallel and use V2B built up to a Princeton type PI section, then try different tone stacks inbetween!
It is probable you can add the 3rd 12AX7 you need for many common and popular designs without overtaxing the PT. It's a nice platform.
Very nice iron.
patrick620
Yes, plenty of iron on those.Teleguy61 wrote:Very nice iron.
stretch2011
Stevem that put a smile on my face!
I Havnt player an 18watt tmb so that would be interesting. I have a couple 14watt el84 variants I could test out
stretch2011
