Super Plexi Naylor
Marshall Amp Discussion
Smokebreak
Super Plexi Naylor
Post by Smokebreak »
Started in on a 50W build today. The idea is a Naylor voiced preamp and presence, with parallel input stages, switchable for jumpered plexi with paralleled input stages there, too. Bells and whistles to follow.
I'll be using Colossal's great relays for the double parallel switch, and for 2 masters for solo boost. http://www.colossalamps.com/DIY.html
I'm gonna put on some acdc and some bugspray and hammer out a board!
10thTx
Re: Super Plexi Naylor
Post by 10thTx »
The 470k/470p on the switch between V1a & V1b will not work. When you throw the switch there is a direct contact leaving the resistor/cap useless.
with respect, 10thtx
Smokebreak
Sure it will! :) Shorting accross the cap/res is exactly what I wanted for the straight Naylor mode, as they have no fixed dividers, just pot to grid. The other pole(s) grounds out the bass channel .
When the switch is in the "up" position, the bass and treble channels are paralleled , and the res/cap becomes a mix resistor for the traditional 470k//470p, 470K. I put a "?" there, as I may go 270Ks, given the 56K/220p stack.
Also, relay 1 and 2 will be linked to trigger at the same time, but you could do it all on a 3PDT panel switch. For anyone looking for that switch that's not of the tiny melty variety, it's NKK S32. Cheapest I found was $8 at Newark.
Ultimately I decided to put it all on the floor, as with the master volume switch, it'll all go on a generic 2 button footswitch, with simple SPSTs on the panel.
10thTx
Post by 10thTx »
OK, now I understand what you are saying and going to do.
You are correct, please accept my apology.
With respect, 10thtx
Smokebreak
No worries my friend, I appreciate the extra set of eyes. Now, allow me to say thank you for the seemingly endless supply of designs you've put up over the years!
10thTx
Post by 10thTx »
I think that switching idea is actually quite clever and innovative. I like it!
Cool idea. I appreciate the gracious response and your sharing the schematic.
Smokebreak
17 1/4' x 3 1/4" board and print-ready drill template/choose-your-own adventure layout
Colossal
Post by Colossal »
Looking really good man. Well done. Gonna be a nice sonic punch in the face.
jhaas
Post by jhaas »
what are the origins of that 10n , 150K boost circuit on the treble pot? I don't recall seeing that before. Is that a boost in the form of increased mids?
Smokebreak
jhaas wrote:what are the origins of that 10n , 150K boost circuit on the treble pot? I don't recall seeing that before. Is that a boost in the form of increased mids?
Yes, that boosts the mids/high mids. I took in a busted Peavey Windsor a few weeks ago, and modded it all over to hot rod JCM800 type thing, but I kept that boost circuit, as it sounded nice. Usually I just parallel caps in for a boost, and just over the treble cap, but this one connects to the treble wiper, which I imagine would change the response dependent on the treble setting...I haven't completely tried to analyzed this difference yet.
It actually seems to be always in the stock configuration, but with a 470K to ground, hindering it's effect, and then puts the 470K across the MV, when the boost is engaged...I think..it's drawn kinda screwy.
This same type thing works great in Fenders. I usually do 1200p series 47K across the 250p and call it FAT
jhaas
Post by jhaas »
Thanks Smokebreak, this is very timely (weird how that happens)
I have a build in the tweaking stage that the customer requested a lead boost. Wanting to make it variable I put a boost pot wired as a variable resistor "under" the volume pot, to ground. Well... that didn't give me what I was looking for at higher volume settings, and since the one half of the boost relay is unused, I thought I'd use it to switch in a mid-boost with it. I was planning on the parallel treble-cap thing as you mentioned, but maybe I'll give this a try.
Cheers!
Smokebreak
Cool! Let me know how it works out. If you've already got the space for the extra pot, you can have 2 MVs, one being for solo volume. You switch out the wipers, and grounds if you are concerned with loading. That AND the mid boost on the same rlay would be quite a kick. Then, if you had both MVs set the same, the effect would be just the mid boost.
Smokebreak
Colossal wrote:Looking really good man. Well done. Gonna be a nice sonic punch in the face.
Thanks Dave! Boards got here today, hopefully I can start wiring up tomorrow.
Colossal
Post by Colossal »
Excellent!
jhaas
Post by jhaas »
Smokebreak wrote:Cool! Let me know how it works out. If you've already got the space for the extra pot, you can have 2 MVs, one being for solo volume. You switch out the wipers, and grounds if you are concerned with loading. That AND the mid boost on the same rlay would be quite a kick. Then, if you had both MVs set the same, the effect would be just the mid boost.
Thanks, but it's a little more complicated than that. :) this is a two channel amp, each with its own MV set up as you describe. I could continue the concept with a third paralleled volume pot and have the boost only apply to the dirt channel, but I'd really like to have the variable boost work with both channels.
I'll report back with the results.
