DIY Airbrake...
Re: DIY Airbrake...
hi guys, I'm decided to build this but I can't found 588-RJS150E RJS150E Ohmite Power Rheostats 50watts 150OHMS on stock, so I wonder If it can be replace for this one Rheostats 50watt 125ohm 750V Std Shaft which is the same but 25ohm less, so the questions are; do I need to use a sitch with a larger ohm value instead? it will work well? is there any issue with temperature?
can it be used with 4, 8, and 16 ohm with no further problems, isn't it? By the way I want to use it with a 45watt amp I'm building.
thanks.
thanks.
Re: DIY Airbrake...
Hi everyone, could someone please send me the pdf and all the project files to: luco_zz [ at ] hotmail.com?
Thanks!!
Thanks!!
Train Wreck
Hello, I'm new in the Forum.
My name is Nuno, I'm bulding the Trainwreck and would like to see if anyone could help me with this.
I have everything together now, but I'm confused with the rotary switching.Where should I lock the rotary switch, it appears that the connection is not made from pins 1 to 6.
Thank you
Thank you
washburnmemphis
Re: DIY Airbrake...
Would appreciate if I could get a copy of the layout for this build.
vadavis (at) yahoo.com
Re: DIY Airbrake...
Hello all - would very much appreciate a copy of the Air Brake schematic and parts list if anyone would be so kind as to PM me with it...
help
I'm new to this site and I don't get it. Where are the schematics and parts lists? Everyone seems to have access to them as they're talking about their builds. I want to build this airbrake. Can someone help?
-Dom
Ampeg VT-40 4x10 combo w/Jensen MOD 10-70
Rolland JC-120 2x12 Combo
Where is the thread about BUILDING an Airbrake? Look here.
Go back to The Amp Garage Forum Index.
Go to Trainwreck Files and look for "Airbrake".
https://tubeamparchive.com/viewtopic.php?t=8733
Re: DIY Airbrake...
I´m after 690-C4D0206N-A switch for shure, but I´m a little confused about how to "clone" the lorlin connection to the new switch, since I see 2 lugs in some of the possitions. What are them? Are they like the poles on the lorlin?TheCowGod wrote:
[img:800:598]http://binrock.net/permanent/2012/0625_airbrake/03.jpg[/img]
So for future builders, I highly recommend the 690-C4D0206N-A switch.
Dan[/url]
I´ve got another doubt. I will go with the no bedrom-level lay-out:
If I want to add a bright cap, with a switch for example, where should it be connected?
Thanks in advance, Gilberto.
Re: DIY Airbrake...
BUMPtraktop wrote:I´m after 690-C4D0206N-A switch for shure, but I´m a little confused about how to "clone" the lorlin connection to the new switch, since I see 2 lugs in some of the possitions. What are them? Are they like the poles on the lorlin?TheCowGod wrote:
Dan[/url]
If I want to add the bright cap, with a switch for example, should I do it at the connection that goes from the 6 possition switch to the output tip¿
Re: DIY Airbrake...
traktop wrote:BUMPtraktop wrote:I´m after 690-C4D0206N-A switch for shure, but I´m a little confused about how to "clone" the lorlin connection to the new switch, since I see 2 lugs in some of the possitions. What are them? Are they like the poles on the lorlin?TheCowGod wrote:
Dan[/url]
vcamargo99
Re: DIY Airbrake...
Forgive my ignorance, but to increase the attenuation level on my AB clone's BEDROOM setting, would it be possible to just replace the large resistors with higher values, like 150watt 25Ohms?
I'm just trying to lower the volume of my 100watt amp for home practice with 2 small kids around. The tone is fine on my AB clone, even on the bedroom setting. It's just as loud as a drummer, and I'm trying to knock it down a notch or two.
Re: DIY Airbrake...
Looking to build one of these.
Could i get the information if some one could see their way to sending it to me.
Pm here, or email;
charlie.boylin at gmail.com.
thanks in advance..
Pm here, or email;
thanks in advance..
LedZepp007
Re: DIY Airbrake...
Dumb question: can I use one of these with a 16-ohm cab? Thanks.
Re: DIY Airbrake...
LedZepp,LedZepp007 wrote:Dumb question: can I use one of these with a 16-ohm cab? Thanks.
Check the search link above, there is an enormous amount of information to be mined on this site. You're still new, but folks will be a lot more inclined to help if you have made an effort to search and find some answers on your own.
To answer your question:
https://tubeamparchive.com/files/kf_airbrake_151.txt
https://tubeamparchive.com/viewtopic.ph ... ke&start=0
Also, start at the beginning of this thread:
https://tubeamparchive.com/viewtopic.ph ... m+airbrake
