 , the other kind.
  , the other kind.
 A friend brought me his dead 5506 Marshall. Previous "shadetree" repairs were evident . There were burn marks around the NPN transistors' legs and the solder had flowed out. The transistors were from different manufacturors and neither from the original Motorola. The fuse was blown. It was rated at 1 amp but someone put a 4 amp in there. I replaced the silicone and cleaned up the mess around the legs. I put a 1 amp fuse in and it went of like a flashbulb. I unsoldered the conections to the transformers secondary and the fuse blew. I checked the primary windings and found a short and an open circuit. It has two primaries for different voltage supplies. Four connections used with jumpers.
I need a source for a replacement. It Looks like it has been replaced before. The numbers are T4969c which is what the schemo calls for. It looks like a Dagnall.
Any suggestions?
Thanks in advance.
LeeMo
