Just got my new Marstan trannie and gonna need some help
Marshall Amp Discussion
harris51
Post by harris51 »
Can anybody tell me where are the high voltage leads on this transformer it's the 1202-55 and Im sure ill be asking many more question about these transformers Thank in advance for once again saving my butt!
harris51
subject
Post by harris51 »
has anyone used these Radio spares from Marstan and can anyone provide any layouts? Thanks
Colossal
Re: Just got my new Marstan trannie and gonna need some help
Post by Colossal »
The two red leads marked HT (stands for the classical High Tension) are the high voltages secondaries. You also need the red/yellow lead marked Ground. That is the high voltage center tap to ground.
Stay safe!
ToneMerc
Re: subject
Post by ToneMerc »
harris51 wrote:has anyone used these Radio spares from Marstan and can anyone provide any layouts? Thanks
http://www.marstran.com/Wiring%20Diagrams.html
TM
harris51
subject
Post by harris51 »
the high voltage (ht) taps are on the same side as the heaters as opposed to the metro trannies is that normal? please excuse the dummy questions and there will be more :)
ToneMerc
Re: subject
Post by ToneMerc »
harris51 wrote:the high voltage (ht) taps are on the same side as the heaters as opposed to the metro trannies is that normal? please excuse the dummy questions and there will be more :)
Not being a smartass here, but it's normal for a Marstran. On the surface it just means you won't have HT leads terminating near the front of the chassis and traveling along the side of the chassis toward the rectifier tube.
TM
harris51
Post by harris51 »
Thank you tone merc
harris51
Post by harris51 »
I trying to get activated to the Marstran forum I guess there busy over there. Im sure Ill have alot of questions hooking the output tranny, till then
thanks a bunch!
harris51
Output tranformer question
Post by harris51 »
running the amp at 8 ohms (2-16 ohm speakers) which are my primary output tranformers wires? :oops:
ToneMerc
Post by ToneMerc »
IMHO, the tag board type RS are easiest to wire. Although I believe MM does offer an " easy wire" version. Neverthless, do a google search, there's info on on the web on how to wire these to a couple od switch options.
TM
Re: Output tranformer question
harris51 wrote:running the amp at 8 ohms (2-16 ohm speakers) which are my primary output tranformers wires? :oops:
What primary impedance do you want to run? With the secondary wired as shown you have three options available, all matching to 8 ohms. FWIW, the original JTM45 used 8k primary for KT66's.
harris51
Post by harris51 »
Im want to run the amp at 8ohms being that i have two 16 ohm speakers.
harris51
Post by harris51 »
so what i hearing from you and seeing on the chart i would wind the 8k wire(brown) and the other 8k wire (brown/w white stripe) and those two would go to v4 and v5?
JazzGuitarGimp
Post by JazzGuitarGimp »
harris51 wrote:Im want to run the amp at 8ohms being that i have two 16 ohm speakers.
Hi Harris51,
Martin is asking you what primary OT impedance you desire. You have answered with the secondary impedance. If you do not know what primary impedance you want, tell us about the output tubes: part number and quantity, as well as your expected B+ voltage, and a description of how you want the amp to sound, and you might get a relevant answer.
Good luck!
harris51 wrote:so what i hearing from you and seeing on the chart i would wind the 8k wire(brown) and the other 8k wire (brown/w white stripe) and those two would go to v4 and v5?
I don't know what you mean by "wind," but yes the ones marked 8k are the ones to use for 8k primary impedance. The diagram doesn't give any phase information, so you will have to guess, and be prepared to swap the Brown and Brown/White leads if it howls. You will probably want to try 6k6 too, and decide which you like better.
