I am interested in how one would keep the pre-amp from distorting, and yet have enough gain to overdrive the output section of the amp. I am modifying a VHT Special 6 Ultra. The clean channel will NOT distort without a pedal. It has only 2 gain stages(1/2 of each 12ax7's). The Ultra channel has 3 gain stages, again, each is 1/2 of a 12ax7. It will distort, but the tone is too "fuzzy". If it is distorting the output section of the amp (a single 6V6), it is being overwhelmed by the pre-amp, and the resulting tone is dissonant.
I have tried a 12au7 in the first position. This did not help, and I really noticed little difference in the tone. I tried a clean booster pedal in the effects loop, and this gave me the best results, but is still too dissonant. Unfortunately, 1 X 12ax7 follows the effects loop. The amp has a Wattage control, which attenuates the plate Voltage, but this type of distortion is still not "sweet".
I do not know how to figure out the limit of a gain stage. An answer to this problem may help me understand the phenomena. Also, is there a limit to a 12ax7's input Voltage(A.C.) ? Is this a choice of tube problem ? I have found that there is definately a difference in tube brands. I bought VHT's EL84 adapter, and tried it with a Mullard RE-issue EL84. It sounded much too fuzzy, and it was next to impossible to play clean with it.
If my problem IS tube related, what parameters are we talking about. Do I need to minimize gain to keep the 12ax7's from distorting. I would think that when I tried the 12au7 this would have happened. Is there such a thing as headroom for a pre-amp tube ?
This is an experiment that I am doing. I'm not saying that output tube only distortion is best. However, I recently spoke with DeLisle Amplifiers about buying one of their custom amps. They told me that their amps are low gain, and made to distort FIRST at the output section, then the phase inverter, and lastly at the pre-amp, so there is precedent for emphasizing output distortion.
All comments and opinions are most welcome, and answers to my questions are greatly desired ! tonequester.
 P.S. I emphasize............I'm not against pre-amp distortion, just don't like fuzz !
