New Sozo caps
Re: New Sozo caps
I think the problem with Sozo is production and providing caps to the large amp building companies and for us bottom feeders we have to wait.
I use M150, Xicon, and Mojo Dijon caps. For Dumble and Fender I'm using 6Ps OD.
I'm going to be using more Xicon film caps as I've had very good results in Marshall Hot Rod Plexi AFD #39. All caps in that amp are Xicon film caps.
Re: New Sozo caps
I must be the only bottom feeder here that typically manages to get Sozo orders in 2 weeks or less. My first order for Nex Gens I placed on 2/27 and 3/6 they were in my mailbox. I just placed another Nex Gen Plexi set order last night, I will post when they show up.M Fowler wrote:I think the problem with Sozo is production and providing caps to the large amp building companies and for us bottom feeders we have to wait.
TM
Re: New Sozo caps
Ordered Sat night 4/5 and they arrived in today's (4/11) mail.ToneMerc wrote:I just placed another Nex Gen Plexi set order last night, I will post when they show up.M Fowler wrote:I think the problem with Sozo is production and providing caps to the large amp building companies and for us bottom feeders we have to wait.
TM
TM
Re: New Sozo caps
I don't use Sozo anymore so I have no experience with ordering only read the complaints so someone else will have to chime in and I'll stay quiet.
capacitor value
Hy Guys, I don't want open a new thread because I wanna talk about sozo-mustar capacitor: I've bought on ebay 4 27nF mustard capacitor to use in 1987 build. Can I use as same of 22nF? are there some important tonal change?
Re: capacitor value
Using 27nF instead of 22nF for will shift the frequency break points down a little less than 1/3 octave, so in general you will get a bit more bass-heavy sound.dariez75 wrote:Hy Guys, I don't want open a new thread because I wanna talk about sozo-mustar capacitor: I've bought on ebay 4 27nF mustard capacitor to use in 1987 build. Can I use as same of 22nF? are there some important tonal change?
Re: New Sozo caps
even if I don't use those in tone circuit but in post Phaese inverter Caps?
Re: New Sozo caps
Yes. The PI coupling caps and the 220k resistors connected to the bias supply make a high-pass filter.  The output impedance of the PI is involved too, but the effect will be to move the low frequency break point lower.  I don't think it will be a big deal though, so go ahead and try it.
						Re: New Sozo caps
Ok martin, you convince me, i try to build whith 22nF 400v orange drop in phase inverter, and after all I'll try to swap with mustard 27nF. In the time I waiting I could put an order of sozo 22nf...
				RockinRocket
Re: New Sozo caps
I got my sozo's in 7 days.
						Re: New Sozo caps
						Re: New Sozo caps
Sounds good. No offense but I've heard JTM45s that I liked better.billyoung wrote:"the sound" https://www.youtube.com/watch?v=AnGsMAnmoi4
see if you can discern the difference ?
billyoung606060 at gmail dot com
If it don't get hot and glow, I don't want it !
						Re: New Sozo caps
						- Littlewyan
Re: New Sozo caps
If you want to listen to many different early Marshalls look at this guy's channel. https://www.youtube.com/channel/UCyaStg ... 1PgH8bUkzg
He'll show you the circuit as well so you can see what spec the amp is.
