Two Rock Classic
keithrick
Re: Two Rock Classic
Post by keithrick »
Nice pics, Looks like Tant's on the bright and mid switches.
brownnote
Post by brownnote »
keithrick wrote:Nice pics, Looks like Tant's on the bright and mid switches.
I was thinking they looked like dipped ceramic, Panasonic maybe.
Remember kids...Always adjust for minimum smoke!
D'Lite Kits: http://store.bnamp.com/dlitekits.html
keithrick
Post by keithrick »
Ahh, your probably right. They look the same as the caps on V1 and V2.
glasman
Post by glasman »
The filter caps look like sprague atoms, according to mouser the atoms are not RoHS compliant...... maybe they are something else.....
About 5 miles south of I-94
www.glaswerks.com
brownnote
Post by brownnote »
glasman wrote:The filter caps look like sprague atoms, according to mouser the atoms are not RoHS compliant...... maybe they are something else.....
More proprietary components no doubt.
It's my understanding that BMI make the Atoms for Vishay/Sprague, the last time I spoke with them they said they could do a run of custom label caps, RoHs was optional (and more expensive).
glasman
Post by glasman »
Good information. I am pretty sure that Mojo was dropping them in favor of TAD and Illinois.
www.glaswerks.com
greiswig
Post by greiswig »
novosibir wrote:
heisthl wrote:Is that a bypass cap on the PI tail resistor?
Yes it is! Means, that the actually presence internal is fixed at '10'.
The Contour control is similar to the VOX cut control operating between the PI's plates - the small 'Orange' below one of the 'Big Blue', what's presumably a 2200p going to a 250K log. pot as the Contour.
Larry
Larry,
There are at least a couple of us who would really appreciate a detailed explanation of this Contour circuit: is it a combination of a resonance and presence control, or what? Any and all detail you have, I for one would appreciate hearing more.
Best,
-g
novosibir
Post by novosibir »
greiswig wrote:There are at least a couple of us who would really appreciate a detailed explanation of this Contour circuit: is it a combination of a resonance and presence control, or what? Any and all detail you have, I for one would appreciate hearing more.
That's easy explained. The Contour is kinda Presence control (not Resonance) and is operating like the cut control in a VOX AC30, only reversed connected to the pot (wiper & output lug), so that when turning the pot CCW the highs are disappearing.
Since the 'new' Presence doesn't 'add' highs, but only is taking off highs, the previous Presence now may be dimed internal, what simply is done by bypassing the 390 ohms R below the 24K tail resistor with the usual 1µF presence cap.
This kind of a Presence control I'm also using in my DINO amps already over 10 years now, look here:
[img:800:533]http://www.larry-amplification.de/dino9 ... 001-01.jpg[/img]
From the two yellow .047 coupling caps next to you (where on its left side the orange & green wire are going off), the right leads are connected to the PI's plates, but additional from one connection a cable, from the other a .0022 cap is going to the 250K log. Presence pot. Quite simple!
But name it "Contour" instead of Presence, then already it seems, that you have something 'special' in your amp :lol:
Larry
Larry's Website now with included Pix's Gallery
glasman
Post by glasman »
The only picture I have seen of the contour circuit looked like a full on wired presence cuitar (1uf cap across the 390 resistor) and a VOX cut circuit that was copied from an AC30. I think the AC30 (or maybe AC15) were the first amplifiers to make use of the PI cut ccircuit.
A .001uf in series with a 250K pot betweeen the PI output couplers and voila you now reinvented the VOX cut circuit. FWIW, Ken Fisher and Komet also used this circuit..... so did matchless and a HOST of others.
Take a look at the AC30 schematics available. Pretty simple
Contour just sounds COOLER than cut....
Gary
www.glaswerks.com
glasman
Post by glasman »
novosibir... we were typing at the same time.
www.glaswerks.com
novosibir
Post by novosibir »
glasman wrote:Contour just sounds COOLER than cut....
That's one way, to dazzle your customers :wink:
But whether it sells some more amps, is another question 8)
glasman wrote:novosibir... we were typing at the same time.
Also easy explained: Telepathy :lol:
Larry
ayan
Post by ayan »
And of course, the mandatory disclaimer: no one will have the complete picture on TR amps, or any Dumble-related matter bar none, unless they read this:
http://thegearpage.net/board/showthread.php?t=331325
I have to admit, it is entertaining. :)
Gil
Normster
Post by Normster »
ayan wrote:And of course, the mandatory disclaimer: no one will have the complete picture on TR amps, or any Dumble-related matter bar none, unless they read this:
Gil
That thread has enough material for a full-season sitcom. :lol:
ayan
Post by ayan »
Normster wrote:That thread has enough material for a full-season sitcom. :lol:
You got that one right, Norm. Screw the writer's strike, who needs them? :)
Gil
v00d00blues79
Post by v00d00blues79 »
heh heh... I started getting nauseous around page 30... :shock:
Andy
