help! my HRM overdrive sounds harsh
yeahyeah
Re: help! my HRM overdrive sounds harsh
Post by yeahyeah »
you have a PM,
and good luck
you have a scope right?
heisthl
Post by heisthl »
yeahyeah wrote: you have a scope right?
and a listerine and probably a lavoris. diagnosis halitosis, :lol:
www.RedPlateAmps.com
heisthl
Post by heisthl »
Sometimes pain and suffering gives you the blues - other times it gives you a great amp to play blues with. I can't wait for the owner to post some clips of this amp now. It had a few problems but let me start off with this disclaimer: "This amp was really a clean nicely done build, definitely a lot of care was taken on the assembly". The main problem was a defective Volume pot (P3 did not make contact with the wafer)This really made for some interesting micophonics and squeals as well as a nasty hum if you had relays engaged with the volume on 0. The second main problem was the tube socket at V1 - much improvement after replacement. The rest of what I did to the amp was putting good coax on some of the runs, putting the owners troubleshooting tweak values back to stock HRM values.Then I put a 10uf bypass on CL2, added a 100R to the HRM tail, added a few tooth washers here and there for better grounding. It is dead quiet now and sings like a bird - I would say Grail tone w/6L6s. Loads of overtones. Curiously the OD is so good in this one you really don't need boost on. Oh one other thing I had to add a connection point to wire the standby correctly. One word of advice to the D'lite builders out there - wire the standby switch so the first filter is charged all the time. The switch goes between the filter and the OT and choke(or RF Mod resistor) entry points.
dogears
Post by dogears »
Good work HH! Do you find some reason why the 100 ohm on the tail is a good idea?? Just curious...
heisthl wrote:Sometimes pain and suffering gives you the blues - other times it gives you a great amp to play blues with. I can't wait for the owner to post some clips of this amp now. It had a few problems but let me start off with this disclaimer: "This amp was really a clean nicely done build, definitely a lot of care was taken on the assembly". The main problem was a defective Volume pot (P3 did not make contact with the wafer)This really made for some interesting micophonics and squeals as well as a nasty hum if you had relays engaged with the volume on 0. The second main problem was the tube socket at V1 - much improvement after replacement. The rest of what I did to the amp was putting good coax on some of the runs, putting the owners troubleshooting tweak values back to stock HRM values.Then I put a 10uf bypass on CL2, added a 100R to the HRM tail, added a few tooth washers here and there for better grounding. It is dead quiet now and sings like a bird - I would say Grail tone w/6L6s. Loads of overtones. Curiously the OD is so good in this one you really don't need boost on. Oh one other thing I had to add a connection point to wire the standby correctly. One word of advice to the D'lite builders out there - wire the standby switch so the first filter is charged all the time. The switch goes between the filter and the OT and choke(or RF Mod resistor) entry points.
heisthl
Post by heisthl »
dogears wrote:Good work HH! Do you find some reason why the 100 ohm on the tail is a good idea?? Just curious...
None whatsoever, I just did it 'cause I've been noticing it in a few HRM pictures I've seen and it makes for one less lead wire when you use it to connect the 2 boards. Based on the way this one sounds I'll be adding it from now on just for the "Mojo" factor.
benoit
Post by benoit »
What does it mean when a resistor value is given as 100r or 470r or whatever? Is it just ohms, or is there more to it?
mlp-mx6
Post by mlp-mx6 »
Just ohms.
Me: Just one more...
yeahyeah
Post by yeahyeah »
Heisthl is the man!
I talked with him on the phone yesterday and he really went above and beyond.
I'll be anxiously awaiting the amp's arival like a 5 year old kid waiting for christmas. I'll report back when it arrives and I'll see if I can get my buddy with a mac to help me record some clips.
skyboltone
Post by skyboltone »
heisthl wrote: One word of advice to the D'lite builders out there - wire the standby switch so the first filter is charged all the time. The switch goes between the filter and the OT and choke(or RF Mod resistor) entry points.
Doesn't that put plate voltage on cold PA tubes? I'd always heard that that's a no no.
Dan
heisthl
Post by heisthl »
Cold tubes? why the heaters are running (the whole point of standby is to allow the heaters to get the tubes up to temp). Maybe you misunderstood the connections - the first filter gets voltage but not the choke or OT.
skyboltone
heisthl wrote:Cold tubes? why the heaters are running (the whole point of standby is to allow the heaters to get the tubes up to temp). Maybe you misunderstood the connections - the first filter gets voltage but not the choke or OT.
Yes I did. In my tiny little mine I saw the OT connected to the + side of the first filter cap and the standby switch before it. It don't have to be that way though. Doh!!
Sorry
Dan
Tonegeek
Post by Tonegeek »
Mine is wired between the diodes and first cap but this way seems like a better idea. Is this just to keep from having such a large inrush when flipping the standby? I would think it is a bit easier on the diodes, fuse, etc.
Pitcher Amplification
http://pitcheramps.com
heisthl
Post by heisthl »
Tonegeek wrote:Mine is wired between the diodes and first cap but this way seems like a better idea. Is this just to keep from having such a large inrush when flipping the standby? I would think it is a bit easier on the diodes, fuse, etc.
That plus it keeps any high voltage spikes away from the later nodes that probably have lower voltage caps. The addition of a .02 1KV disc cap across the Standby switch is another good thing to add.
JimiB
Post by JimiB »
whats your thought on using a MOV here instead?
novosibir
Post by novosibir »
heisthl wrote:The addition of a .02 1KV disc cap across the Standby switch is another good thing to add.
When you have the first filter caps on the hot side of the standby switch, then I'd recommend the .02/1kV cap from the cold side of the switch to ground.
Larry
Larry's Website now with included Pix's Gallery
