Ultimate Hammond Conversions thread
I've seen a lot of info scattered around the forum on converting Hammond organ (and other brands of course) iron and chassis into guitar amp builds and wanted to create a thread for it. I had a few side conversations with other members on the forum and by coincidence, two of us are sitting on Hammond AO-43 chassis and we both are starting them shortly.
For those of us who like to feel "environ-mentally responsible" there are several chassis from different Hammond models that seem to be popular candidates for conversion:
AO29 - M-1 series
AO14 M-2 series
AO35 M3?
AO43 - L series
AO71 - H series
I also have a very old S-series I am disassembling. The chassis is much too large, but the iron should be useful as it has a 6v6 pair for the output.
Specs on the AO-43 original configurations:
Tube complement -
2 -el84/6BQ5 output section
5U4 rectifier
2 - 12ax7 preamp
1 12BH7 (I believe this was the reverb tube, but the reverb unit itself was offboard in a separate chassis). Nonetheless, its an extra useful noval socket.
Transformer info (from the service manual schematics)
T302 PT, pn AO-24157
5v 3A
315v secondary (Listed on schematic as 160mA AFTER the 64R wirewound resistor (so B+1 is approx 1.4 x 315 at or around 440v?)
6.3v approx 1.8A
315v at plate on the schematics, but that's after more dropping resistors.
14H choke
I'll start with some photo's of the prep work. My approach here is a total shoestring. I'm going to at least attempt to re-use every component possible save for the PS caps, and tone stack caps /resistors. I'm even likely to re-use this funky turret-eyelet hybrid board.
I'd like opinions from "the asylum residents" as to what you think is the best choice for conversion. This one is a bit too hot for a 2xel84 Rocket, but I am considering a big ol' Zener to drop the B+. Other builds considered were an 18 watt stout sort of thing, or an ef86 side and a 12ax7 side. I'm a high gain guy, and I use pedals. It needs to be simple 'cause I'm new to this, and I normally use single channel amps. I'd like to try a Rocket....just not sure how best to drop the secondary volts coming off the PT.
AO29 - M-1 series
AO14 M-2 series
AO35 M3?
AO43 - L series
AO71 - H series
Tube complement -
5U4 rectifier
2 - 12ax7 preamp
5v 3A
6.3v approx 1.8A
14H choke
- lord preset
Re: Ultimate Hammond Conversions thread
I am just getting ready to start an AO-39 conversion - also 2-el84 and similar voltages but it's a smaller chassis. I'm using this as a guide to do an 18 watt Lite build:
http://home.comcast.net/~seluckey/amps/ ... ammond.htm
The author was able to drop B+ by using a 5Y3 rectifier tube and a beefy power resistor.
eniam rognab
hey don! cool thread
i am starting a half power rocket with AO-43 irons! new chassis though, got the PT mounted and i am playing around with OT/choke locations
im looking forward to sharing this with all of you, so you can laugh at my noobness!!
to hammond!
to hammond!
Cool, preset! I also looked at a 5Y3, because I have a couple old stock ones but it would also have to have some other extra drop to bring my B+ down. I thought about using resistors. I'm going to take a closer look at those pix. Since this link is using the ef86, that is the "non top-boost" Vox channel correct?
Nice chassis eniam...you're going to make mine look bad, aren'tcha?
I'm going to "reverse" my pots and use the unscathed side of mine as the front. To keep my lead dress short, that means the knobs will be more to the right side (facing the front) than a standard Rocket. But I'm OK with that. Alternately I thought of placing a new plate on the side that's punched with odd holes. Either way, I'm going to use a mahogany face plate overlay so it will match my Express build.
eniam rognab
imma do like a swirley finish on my chassis with sand paper or a wire brush or something, and label my knobs crazy talk,
more-uppers-downers-talent-engage-liftoff-spunk-exacerbate
tee-hee!
tee-hee!
I'm curious what tonal differences (if any) would be introduced by using the resistor (as in the AO-39 conversion they use a 250R with the 5Y3 to drop B+) vs. a Zener "dump" in the same place. My preference would be whatever way has the least effect on the tone/response. I know the 5Y3 has the most sag of the rectifier choices.
If you use a 5U4GB, B+ will be ~375. If your choice of amps requires less than 125mA, you can use a 5Y3GT which will give you B+ ~345. I dislike the Zener approach, etc. Maybe that's just me. Solid state, you will won't get quite as high as 440 -- I think maybe ~425 after ordinary losses if you are "lucky." I usually figure the loss at around 4%.donzoid wrote: 315v secondary (Listed on schematic as 160mA AFTER the 64R wirewound resistor (so B+1 is approx 1.4 x 315 at or around 440v?)
If you think the choke is up to the job of taking the current load of the whole amp, you might go for choke input (between rectifier and B+1) which should shave 10% off the B+. With a 5U4GB, that should get to ~310, which a pair of EL84 should be able to manage. 6AQ5 will also survive at 310 OK. Certainly 6V6, no problem!
OTOH, line voltage might be higher these days, contributing extra voltage on the secondary.
I use organ iron and other parts all the time. You have a great start to an 18 watt with that 0-43 chassis. Here's what I did with an older Conn chassis. Hammond AO-43 PT and wurlitzer OT
https://tubeamparchive.com/viewtopic.php?t=24307
"It Happens"
Forrest Gump
Forrest Gump
eniam rognab
yay my first question, hope its a good one!
so, im doing the headphone (actually meter) trick to place my OT. i found a spot next to the PT that reads 5mV and i think i am happy with that. however i still need to locate the choke and i am wondering what steps i need to take to ensure it doesnt couple with my output. OR should i not worry about it and mount it wherever convenient.
is there a way to include a choke in my headphone trick test?
fyi, the OT measures 0mV when placed on the left side far back, 90 degrees to where it is in the pic. should i just put it there instead? i would like the real-estate for my tubes and such but if that is better i will go with that. it does seem like kind of a fuster-cluck with all that iron in one place!
any and all input appreciated!
neal
hi passfan, recognize anything?
neal
eniam rognab
haha yup bigger more better
so i decided to mount the OT on the far left corner so disregard that ugly picture
but i am still wondering about choke coupling, is this an issue?
- lord preset
The link mostly addresses an EF86 AC-15 Lite circuit, so yes, non-top boost, but the author also did a Marshall Lite with the same chassis. Both are documented in the pdf at the end of the article. I am going for the Marshall circuit because I'm doing this on the ultra-cheap with existing parts/tubes and I used my spare Ef86 in a previous build.donzoid wrote:Cool, preset! I also looked at a 5Y3, because I have a couple old stock ones but it would also have to have some other extra drop to bring my B+ down. I thought about using resistors. I'm going to take a closer look at those pix. Since this link is using the ef86, that is the "non top-boost" Vox channel correct?
