want 2 Rok JM signature tone board layout
sunny
Re: want 2 Rok JM signature tone board layout
Post by sunny »
Thanks Mark, and nice build bye the way!
Sounds great, I cant wait to hear some samples!! :P
Paul
Yeah about those sound samples, I've been meaning to set up a mixing station for about 5 years or so :oops:
amplifiednation
Post by amplifiednation »
I've got a set of faceplates for that chassis but there are amp nation logos all over them!
If you want the design files give me a shout I'll help you get some plates made
T
Amplified Nation
www.amplifiednation.com
@ampnation
Taylor I emailed you thanks.
sunny
Post by sunny »
Mark, do you have some kind of ''simple'' layout like this one for example https://tubeamparchive.com/download/file.php?id=30708 ?
It's a little blurry for me when i look at the schematic and the pictures :oops:
I am not a pro like most of the guys here. It would make it a lot easier for me :roll: it's hard to say what is going on underneath the boards.
Paul
sunny wrote:Mark, do you have some kind of ''simple'' layout like this one for example https://tubeamparchive.com/download/file.php?id=30708 ?
Paul
I'm sorry I do not have a layout for you to go by.
I had to use the schematic and photos on my build.
Under the tone board is mostly ground connections to all the preamp cathode resistors/bypass caps.
The other connections could be done from the top if you wanted. I know I don't like wiring boards underneath like this, twice as hard in my opinion.
The PS board could be built differently too.
Added new faceplate looks better now. :lol:
dorrisant
Post by dorrisant »
Mark,
What were your voltages? I found some handwritten documentation that had some... Just curious if you know off-hand.
After your glorious comments I have to build this circuit. Good looking build!
dorrisant wrote:Mark,
Tony I will have to take voltages again and write them down and post.
dorrisant
Post by dorrisant »
Thanks Mark. You are a machine!!!
beasleybodyshop
Post by beasleybodyshop »
I have been using my horribly meager layout skills to come up with a layout for this amp based on the photos in this thread and Aaron's schematic. Please forgive the squiggly lines, inkscape is a bitch to get smooth lines.
This layout is not complete, so use at your own risk! Any feedback for correctness would be fantastic.
Aaron
Post by Aaron »
Nice work on the layout. It takes me about the same time drawing a layout as it does to build it!
Aaron
beasleybodyshop
thanks Aaron! Your schematic was invaluable. I wouldn't have been able to do this without it and Marks guidance.
dorrisant
Post by dorrisant »
Nice looking layout! What are you using to draw that up with?
