Stupid on/off and standby switch question?
https://tubeamparchive.com/files/rocket ... 09_860.pdf
If I look at this layout the switches are off in the down position and on in the up position.
This seems to go against convention.
What is the correct orientation?
Thanks for your help.
Yours Sincerely
Mark Abbott
Mark Abbott
Re: Stupid on/off and standby switch question?
Hi Mark
Yes down is off and flip the switch up for ON, or at least that's the way I saw it too....most amps up for on.
Is there a "correct" position?
The uncertainty may be due to the different switch conventions used in North America and here in Australia ( where Mark and I reside ). Here, a toggle or rocker switch is ON in the DOWN position, whilst in North America UP is ON.JoeCon wrote: Is there a "correct" position?
It can take several days for us antipodeans to adjust to the upside down light switches in North American buildings.
- JazzGuitarGimp
That's just crazy! If I were you, I'd get all those light switches flipped over... Oh wait, I'm starting to sound just like the US government, pushing their ideals on other countries...darryl_h wrote:The uncertainty may be due to the different switch conventions used in North America and here in Australia ( where Mark and I reside ). Here, a toggle or rocker switch is ON in the DOWN position, whilst in North America UP is ON.JoeCon wrote: Is there a "correct" position?
JazzGuitarGimp wrote:That's just crazy! If I were you, I'd get all those light switches flipped over... Oh wait, I'm starting to sound just like the US government, pushing their ideals on other countries...darryl_h wrote:The uncertainty may be due to the different switch conventions used in North America and here in Australia ( where Mark and I reside ). Here, a toggle or rocker switch is ON in the DOWN position, whilst in North America UP is ON.JoeCon wrote: Is there a "correct" position?
Yep, USA up is on down off. Marshall amps down is on up is off. and most any other amps across the pond.. And many times the layouts are reversed. inputs on the left . other amps inputs on the right side. Wonder if this applies to the way the drain swirl direction goes..
vibratoking
People in most countries feel Americans are stupid, so they find a better way to do EVERYTHING, even if it's not.
Switches, schematics, decimal points, the numbers one and seven, z and zed, paper size, etc...
I once had someone complain that the switch positions in a dual switched kitchen light kept changing. In this case, it didn't matter whether she was American or not.
Oh, how about orienting the switch sideways? Left is off and right is on.
- Reeltarded
Right on.
vibratoking
That's how I remember where to plug into most effects boxes...plug right in. I was dissapointed when I realized that it doesn't always work. I'll try counting to ten, if you don't mind.
This is fascinating. I didn't realize that Britain/Australia were different. I lived in Australia for most of a year, but since the switch types always looked different, I just thought it was due to being a different style (or that I was around poorly wired things). Anyways, I don't remember now and I can be rather oblivious.
I knew Marshalls were upside-down, but I always thought that was tradition and leaving things exactly as a Bassman plopped into head format. I didn't realize other Brit amps were the same and for other reasons.
oops! sorry!
I'll make use of this accidental post and ask about the story with this:
http://bavasmusic.com.au/store/images/59Bassman_top.jpg
vibratoking
That was done wrong from the start... stupid Americans.
Well. the Aussie switches are pr convention....
You just have to remember they are" down under, so their switches are upside down... "
I don't like any of this
Switches up for on and darn it the input jack goes to the left what the hell is wrong with you guys over there and under there.
Thanks for the replies, I thought Ken Fischer would have followed the Marshall convention of down is on. After years of seeing and using amps with this orientation it seems very natural.
Perhaps I should fix this obvious oversight.
Yours Sincerely
Mark Abbott
Mark Abbott
Up or down? Just look at the bloody pilot light lads!
