Issue With Bassman 5F6A Build
Fender Amp Discussion
Re: Issue With Bassman 5F6A Build
Make note to your self for future amp builds take those burned out old preamp tubes and insert into the tube socket before you solder the tube pins.
That way you won't have solder running into the tube sockets. I found out the hard way :)
Guitarnut
Post by Guitarnut »
M Fowler wrote:Make note to your self for future amp builds take those burned out old preamp tubes and insert into the tube socket before you solder the tube pins.
Ha! I actually thought about it but the thought of accidently soldering a tube into the socket would be even more embarrassing when I had to ask for help with getting it out.
Will the pins not take solder? Never tried.
Not really. It is a great tip for a couple reasons that aren't apparent until you do a few. Tubes swap in easier if the pins are already lined up perfectly. Easier feeding means less grumbling and pin bending... or breaking.
Of course I have never grumbled or bent a pin..
:oops:
No I've never soldered in a tube. :)
Blackburn
Post by Blackburn »
I've gotten pins all bent outa shape a few times. Stupid ass pins won't do what I tell them to. Then I gotta go all medieval on its ass!
vibratoking
Post by vibratoking »
I've gotten pins all bent outa shape a few times. ...
I thought that was supposed to happen.
Blackburn
Post by Blackburn »
Just on the novals!
And not the octals... :shock:
Tillydog
Post by Tillydog »
Guitarnut wrote:..I think there's a bit of solder remaining in some of the pin holes...
...Any suggestions for cleaning this out
If we're playing bush mechanics: you can take the socket out, hold it in your hand with the solder connections pointing down and get the blocked pin good and hot with the soldering iron, then quickly whack your hand down onto the bench so that the still molten solder is shocked out of the hole. The idea is to hit your hand on the bench, rather than the socket to avoid smashing it!
I used to de-solder PCBs this way to salvage components before I had a solder-sucker / money to buy new parts.
HTH :)
JazzGuitarGimp
Post by JazzGuitarGimp »
Tillydog wrote:I used to de-solder PCBs this way to salvage components before I had a solder-sucker / money to buy new parts.HTH :)
Umph.... visions of my past coming back to haunt me.... I used to do this with pcb's too, and until now, I had thankfully forgotten all about it! :-) Actually, I used to slap the board on the bench to evacuate component holes after removing the component..... Such finesse!
Tillydog
Post by Tillydog »
I used to fish the boards out of the river, too!! :oops:
(Local TV 'repair' shop used to dump old sets down an embankment where they rolled into the river - all illegal, of course, but nobody was bothered in the late '70s. People are paying top dollar for those old carbon comp resistors & crappy caps now - maybe I should buy the land and open a mojo mine??) :lol:
Oh stop writing songs!
down there diggin back in time
nouveau riche in the mojo mine
That's exactly where I used to get my resistors and OD caps back in the day from old TV's when dump grounds were a plenty.
NickC
Post by NickC »
Back in the day, in Detroit, the city let folks haul their dead TVs to the curb one night a year. The city trash department would take them the next morning. Except for the ones my buddies and I would stuff into cars, and later scavenge parts from.
Tillydog
Post by Tillydog »
Ahhh! Nostalgia isn't as good as it used to be......
Anyway, isn't someone around here building an amp ?? :roll:
JazzGuitarGimp
Hey Mark,
Any progress on your build?
