Guitarnut wrote:ToneMerc wrote:I don't get Mojo sometimes; that is about the worse power transformer design than one could spec for a Tweed Bassman, that is the perfect PT to make a Tweed Bassman very loud and stiff.
TM
Hi TM,
What is it about this transformer that you don't like?
What trans would be a better choice? I know there are very expensive options but I need to keep it in the $150 range if I upgrade.
Peace,
Part of the magic with a Tweed 4-10 Bassman is the power supply and the current rating of the power transfomer. Far too much attention is paid to tube rectifier "sag" and not enough attention to the PT that couldn't keep up. The transformer that Mojo sells would be great for a BF or 70's SF, but is far to heavy in the HT rating as listed. I think there are some assumptions that all Fender power transformers are the generally the same and from a vendor like Mojo, it's certainly easier to stock a few generic transformers.
Victoria IIRC at one time sold a proper substitute PT to the public and I believe the Mercury tone clone has the correct HT rating, but is wound for 110/115V primary, unless you get it would for modern mains voltages.
My personal mantra is that I try to include many of the small nuances that contribute to the total original recipe, but you do you, my method may not be for you. If you are happy with your build, thats all that matters. However, I like to make folks aware when I see things that are not really accurate in some way.
TM
