Small Special
Re: Small Special
EVM 12L :D
lovetone
Schenatic
Post by lovetone »
I Know this is an old thread but just wondered which schematic you used for this?
jelle
Re: Small Special
Post by jelle »
I used the 60's schem from Schematicheaven. Jelle
alvarezh
Re: Small Special
Post by alvarezh »
Jelle, the schematic I am showing is supposed to be from the Small Special, if so, there should be a cap right before the Master Volume. Do you recall the value you have used?
Thank in advance.
Horacio
Play in tune and B#!
ChrisM
Re: Small Special
Post by ChrisM »
alvarezh wrote:Jelle, the schematic I am showing is supposed to be from the Small Special, if so, there should be a cap right before the Master Volume. Do you recall the value you have used?
Thank in advance.
NFB resistor sure looks wrong.
jelle
Re: Small Special
Post by jelle »
Thank in advance.
:D See: https://tubeamparchive.com/download/file.php?id=20597
alvarezh
Re: Small Special
Post by alvarezh »
Ha, ha, nice one Jelle, another of your Masterpieces with values completely different than the schematic! :D
Got the message: build and experiment!
I fully understand your position, no hard feelings on this side. :wink:
Thanks anyways.
@Chris: The values on the schematic seem like they were measured directly from the components, that for the resistors and voltages at least. But the NFB most likely be 930 ohms, right? We'll just have to experiment!
Nice catch.
All the best guys.
Horacio
jelle
Re: Small Special
Post by jelle »
Haha! I figured that it would be a .01 or a .02uF. I had the NOS .02uF so that was easy! :lol:
Besides, it is not about the exact values. It is about creating a great sounding amp.
That NFB resistor is a 820r or higher. The person who made the 60's schem on schematicheaven prob did not know that the OT secondary shunted the reading. Also, the PI couplers are .1uF. I had .15uF, so that is what I used.
The owner *loves* the amp. :D
alvarezh
Re: Small Special
Post by alvarezh »
"The owner *loves* the amp"
I have no doubt on that assertion. One only has to look at the linked image for confirmation; you're a great craftsman!
Thanks for the info.
Cheers!
Horacio
LeftyStrat
Re: Small Special
Post by LeftyStrat »
jelle wrote:Besides, it is not about the exact values. It is about creating a great sounding amp.
Jelle, true words to live by. I love to cook, but I can never follow a recipe exactly. Always got to kick it up a notch.
jelle
Re: Small Special
Post by jelle »
Reminds me... more chili peppers in my pasta souce. Late dinner... :-) Thanks!
andrew
Re: Small Special
Post by andrew »
If anyone could help me please I do not want to use the guitar/mic or the deep control. Do I go from the bottom of the treble control directly to the middle of the volume pot? Thanks for any help.
tictac
Re: Small Special
Post by tictac »
There are two ways you can rewire...
1) Looking at the schematic, connect the bottom lug of the treble control to the top lug of the bass control....
2) Leave the cap connection to the middle lug of the bass pot but remove the connection between the middle and top lug. Then connect the bottom treble lug to the middle lug of the bass pot.
#2 is similar to the circuit used in some Fender Blackface amps.
TT
andrew
Re: Small Special
Post by andrew »
Thanks for the help TT and I'll try it tonight.
Synchu
Re: Small Special
Post by Synchu »
Some time reader, first time poster :)
What chassis can be used for this one? I can order a 483 mmx170 mmx65 mm (roughly 19x7x2.6 in inches) one pretty cheap here.
Will this be alright?
Niki
