What I'm missing ? The 6L6's were biased at -40mV(A) (DMM connected to back panel bias points (1ohm resistor method). I swapped to EL34's and the meter shows (+)2mV(A) ??
I have the pin 1&8 tied together of the octals and then they go via 1ohm resistors to ground.
I did not know that bias can differ so much depending of the tube
I tried a pair of EH EL34s last night, and immediately noticed an increase in the upper midrange. I'll need to crank it up tonight and give it a workout before I decide. B+ = 465V, bias at 31mA.
BobW wrote:I tried a pair of EH EL34s last night, and immediately noticed an increase in the upper midrange. I'll need to crank it up tonight and give it a workout before I decide. B+ = 465V, bias at 31mA.
Just measure the current across the 1 ohm to ground on pin 8! Same as a 6L6. Set them at 30-32ma for starters.
Yes, that much I know, but I was sure when I searched for the bias current of the EL34's on the forum I found suggestion to put them at 50mA, but that depends always also of the B+..
They are now 31.5 and do sound smoother on the clean channel. I cannot crank the OD channel any more today
Is your amp individual bias or both tubes at once?? If it is both at once, I'd set to 60ma-65ma
If it is seperate tube adjustments, then you are good now.
Well after cranking the amp with EL34s installed, I then tried a combo of 1 6L6 (Winged C) and an EL34 (EH). I liked the tone of the mixed set, and here's what I have concluded:
6L6 pair cleanest, Less overdrive
EL34 pair brightest, more upper midrange and overdrive (maybe due to EL34 gain increase)
6L6/EL34 pair more upper midrange and more overdrive (maybe due to asymmetrical clipping).
I know these are ambiguous terms, so this weekend, I'll try to scope out the waveforms w/sine wave input and capture them on a digital scope.
