Congratulations on a great build.
Thank You, clips will follow imediatly when I get the OD to work in a right way.
I hope some can clarifying these few points before I embark on my build.
I'll try on some of the questions.
Are the value of the diodes you used 1 amps 1000 volts ? (1N4007)
Yes, they are 1N4007.
What type, model and brand of relays are used ?
Takamishava RY5W-K
Are the yellow resistors used carbon film ?
Yes.
Are the Vishay Dale RN65 metal film the brown coloured ones ?
Yes.
Is the yellow wire running from the board located next to the transformer with the 56 k resistor links up to the bias point were the pair of 220k resistors join ?
Sorry, I don't quite get this one. The 220k's (not connected) get their bias voltage from two seperate trimmers. Yellow wire was used. Btw. What picture are You referring to ?
Next to the output jack there is a switch with two resistors in parallel that are missing there values and have ?? on them. Does the switch change the amp from a 100 watts to 50 watts ? What should the value of the resistors be and how should they be hooked up in the circuit ?
Yes, I supose that is the half power switch. Sorry, dont know the values.
On the top right hand side board is the NTE 152 a:-
1. Silicon Complementary NPN Transistor. Audio Power Amplifier, Switch.
NTE 152 OR
2. NTE152 : Silicon Complementary Transistors Audio Power Amplifier, Switch
No idea, I used 2n4416.
On the same board what are the small blue oval components - one is located next to the 2K7 resistor - what are these components and what is there value ? Is there any brand that you use specifically for these ?
They are 5uF electrolytic caps.
On the lower board there is also a capacitor that is green in colour is this value 500 pf ? On the same board are the value of the trim pots 20 k, 1M    and 250 k ?
Correct (the 500pF is ceramic).
On the main board were the coupling capacitors are located are all other points that are not connected to any other components actually connected to earth ?
Yes there are few groud line missing. If assume Normster has not finished this build/layout yet. Might be busy with the D-Lites
Where did you get the chassis and boards from ?
http://www.uraltone.com/kauppa/index.ph ... a7b19f4371
What type of transformers did you use ?
PT=TV19 and OT=NSC018343
cheers,
