123 Schematic
				stratcat62
Re: 123 Schematic
I played #115, the sister amp to #123 and can confirm that it was absolutely clean all the way up on the clean channel. I was playing a rosewood Strat. There was a slight amount of grit with the PAB on, but otherwise clean no matter how the amp was set. I can't recall how much the input volume affected the OD on that amp. Sounded great. I think he was asking $75,000 for it.
						Re: 123 Schematic
I wonder, Max....do you think the Carlton Last Nite amp was a low or high plate classic?
						Re: 123 Schematic
I don't know and can only speculate: Taking into acount all I know and his guitar sound at this Baked Potatoe gig I think it's more probable a high plate classic. But to avoid misunderstandings I'll add that I played low plate classic amps that have IMO been less similar to other low plate classic amps from the same period then to some of the high plate classic amps I played. IMO a player familiar with Dumble amps and used to adjust his technique to the way an amp reacts will be able to get rather similar tones with a low plate and a high plate classic amp. So IMO the sound of Larry Carlton at this time was perhaps more influenced by his external EQ e.g. than by the difference a low plate "classic" amp would have made (if he really played the high plate version at the Baked Potatoe). Perhaps this video might be of interest in this context: http://www.youtube.com/watch?v=k6GIQbR6Uh0Dr d wrote:I wonder, Max....do you think the Carlton Last Nite amp was low or high plate classic?
Max
Re: 123 Schematic
Thanks for that Max! Always interested to hear your opinion.
						Re: 123 Schematic
I thought I remember Gil saying it was a high plate classic.. Maybe he can confirm this..Larry used to have the AudioArts parametric EQ n his rack...I think he used his Valley arts guitar on most of that CD..Love that tone he got btw..Dr d wrote:I wonder, Max....do you think the Carlton Last Nite amp was a low or high plate classic?
						Re: 123 Schematic
I don't know whether it was a high or low plate classic.  But as you point out, Tony, between the AudioArts parametric EQ and the midrange boost on the Valley Arts Strat, all bets are off.  I used to have just that for a while and the effect of the EQ and active electroncis in the guitar was so strong that the amp became much more of a secondary thing.
Gil
						Gil
talbany wrote:I thought I remember Gil saying it was a high plate classic.. Maybe he can confirm this..Larry used to have the AudioArts parametric EQ n his rack...I think he used his Valley arts guitar on most of that CD..Love that tone he got btw..Dr d wrote:I wonder, Max....do you think the Carlton Last Nite amp was a low or high plate classic?
Re: 123 Schematic
Thanks Gilayan wrote:I don't know whether it was a high or low plate classic. But as you point out, Tony, between the AudioArts parametric EQ and the midrange boost on the Valley Arts Strat, all bets are off. I used to have just that for a while and the effect of the EQ and active electroncis in the guitar was so strong that the amp became much more of a secondary thing.
Gil
So we are looking at 5 possibly 6 different pre amps at work
Guitar
Amp
Lator
EQ
Verb/delay
Anything else he had on the floor
						Re: 123 Schematic
His reverb and/or delay didn't have an output level so he also ran the amp through a mixer...  Lots'a cheese!
Gil
						Gil
talbany wrote:Thanks Gilayan wrote:I don't know whether it was a high or low plate classic. But as you point out, Tony, between the AudioArts parametric EQ and the midrange boost on the Valley Arts Strat, all bets are off. I used to have just that for a while and the effect of the EQ and active electroncis in the guitar was so strong that the amp became much more of a secondary thing.
Gil
talbany wrote: I thought I remember Gil saying it was a high plate classic.. Maybe he can confirm this..Larry used to have the AudioArts parametric EQ n his rack...I think he used his Valley arts guitar on most of that CD..Love that tone he got btw..
So we are looking at 5 possibly 6 different pre amps at work![]()
Guitar
Amp
Lator
EQ
Verb/delay
Anything else he had on the floor![]()
Re: 123 Schematic
Larry has better Cheese than me.. This is all I got..Lots'a cheese!
T
				Bombacaototal
Re: 123 Schematic
Are the pots on tonestack Ka?10thTx wrote:OK, thanks Tony ! Very generous of you to share with us.
Please consider this schematic as a DRAFT until we get some more eyes on it looking for errors & comments are made.
Once that is done, I will correct it & delete the previous schematic.
Q1: Value guesses on the power tube cathode resistor and diode?
Q2: Value guess on the bias?
Q3: Want this posted with a 404k resistor or a 500k pot regarding the OD
tone control?
With respect, 10thtx
