Hi All,
I'm working on a design that will convert a 5879 from a pentode to a triode in the first gain stage. It will be on the front panel and will have to carry some B+. My first instinct is to use the same sort of switch I use for the on/off and standby but those have a decided click in operation. Since this may be used on the fly, it would be nice to flip it on the QT.
Does anyone use or recommend a medium/duty switch that is really quiet?
Thanks, Skip
Need a quiet switch
- Luthierwnc
Re: Need a quiet switch
My thought is that if you are switching it on the fly, the resulting pop through the speakers will drown out any mechanical click noise from the switch.
- Luthierwnc
I've got some tricks there to unload the grids. I'd still like like a click-less switch. sh
Re: bump
You wont find a click less switch that is mechanicalLuthierwnc wrote:anyone?
Maybe Mosfet
- Kagliostro
The problem isn't in the mechanical noise but in the loud pop
You can try this
[img:799:481]http://www.mediafire.com/convkey/dd7e/h ... wdy25g.jpg[/img]
K
You can try this
K
- Luthierwnc
Here's what I was going to do.
But I still would like a recommendation on a switch that doesn't sound like someone snapped its ass with a wet towel. sh
