6G15 Reverb
6G15 Reverb
Just finished building one of these. Sounds really good but I end up having to run the dwell and mix quite low otherwise is is to over the top. Any thoughts?
Cliff Schecht
Re: 6G15 Reverb
Get a different tank? Or easier than that is to try to remove a spring, but then you'll lose some of the lushness of the typical Fender reverb.
Cliff Schecht - Circuit P.I.
Re: 6G15 Reverb
Maybe you have the pan mounted the wrong way? Some pans are horizontal mount, others are vertical mount. Check the pan code is correct for the way you have it mounted.
Re: 6G15 Reverb
Did you use a 12AT7 at the input stage?
I own an original copy and built a clone. They do not sound the same, even if I switch tanks and / or tubes. Both are nice, but I prefer the original.
[IMG:639:426]http://i55.tinypic.com/16c9x8m.jpg[/img]
Re: 6G15 Reverb
Tanks are or are not what they used to be. I'm not trying to be witty, either. The point is, the original Gibbs tanks are no longer available. There is quite a bit of reading material if you search for "reverb tank review" and it may be instructive to see what people are saying.
Gibbs became Accutronics, which was purchased by Belton, a Korean company AFAIK. A "new" player, MOD has appeared in the marketplace and the reading I've done suggests that MOD may yet eat Accutronics lunch. I don't really know, though. (Aside, I have no idea who makes MOD, and I wouldn't be surprised if they come from the same factory. Call me a cynic.)
Here are some random samples for reading:
http://www.tdpri.com/forum/archive/inde ... 76899.html
http://www.amazon.com/MOD-Reverb-Tanks- ... ewpoints=1
http://www.300guitars.com/2009/12/mod-reverb-tanks/
Re: 6G15 Reverb
Thanks for the information and links to the MOD tanks. They look really nice.
As I indicated, I have tried swapping tanks in my two reverbs without a whole lot of success. The difference in sound between my vintage unit and the clone seems to be in the rest of the components, not the tank. Having said that, I would still be interested to try a MOD tank to see how it sounds in BOTH reverbs.
I guess the only way to really make a valid comparison is to use the clone on and off for forty years to see how the components age
BTW: I did do a filter cap job on the original and updated to a three prong plug without altering the mojo.
Re: 6G15 Reverb
I mentioned forty years of ageing. Actually, the original Reverb is a 1965, so it is 47 years old. It goes well with my 51 year old Bandmaster.
I wish I could say that I bought these recently using the profits from some iphone app I wrote in my dorm room as a college freshman, but that is not the case. Both were bought used, but within a few years of their birth. I am 11 years older than my Bandmaster
No gigs for a long-long time, but still loving bringing the vintage gear back to life and building clones and pedals, just for fun.
Re: 6G15 Reverb
The problem I am having is that anything above 1/4 on the dwell and mix and I am in sponge bob land.
Re: 6G15 Reverb
I will think about that and try to do some comparison experiments.
As I mentioned before do you have a 12AT7 in the first stage? A 12AX7 would have too much gain.
Re: 6G15 Reverb
12at7 in first
6k6gt driver
12ax7 recovery
6k6gt driver
12ax7 recovery
Re: 6G15 Reverb
With it switched off via the pedal, is the unit providing a boost to the clean signal? Cut? If it's not reducing the dry signal I'd reduce the wet side's gain in the 1st stage on the 12at7. Go with a lower resistor than 10k between the plate resistor and the PS. Maybe 8 or 5k.
Paul Fawcett
Re: 6G15 Reverb
jon wrote:The problem I am having is that anything above 1/4 on the dwell and mix and I am in sponge bob land.
Try various sizes of resistor from the wiper to the dry side of the mix control. For my 6G15-inspired build (there were some differences), about 100K was just about right.
Re: 6G15 Reverb
Hi Jon
I have been wanting to build one of these for a while. When I first got into the amp building thing, I bought a Torres stand alone reverb kit. This was a huge mistake, the parts and chassis were rubbish.
I did experiment with this circuit, I found it was very easy to get the reverb unit to distort and if I tried things like split loads on the plate of the amplification stages the reverb sounded flat and lifeless.
Then there is the matter of mounting the spring, the originals weren't simply bolt to the cab, there were screws and springs used in an effort to isolate the spring from spurious noises. There was also a locking mechanism too.
Perhaps Kazooman can show us detailed shots of his original unit?
Keep me in the loop Jon.
Yours Sincerely
Mark Abbott
Mark Abbott
Re: 6G15 Reverb
I'm already exploring this. and I will keep you in the loop.
Re: 6G15 Reverb
Glad to help. I will take some pictures today and will post them soon.Mark wrote:Hi Jon
You are correct that the pan is mounted with springs at the four corners to isolate it from vibration. There is a metal arm that can be used to clamp the pan down firmly for transporting the unit.
When I built my clone I ended up with a pan that needed to be mounted face down and this created some space problems in the enclosure. I had to change the location of some of the components on the chassis. I did mount the pan with springs.
