I decided to build a 4-EL84 amp, using a 270-0-270 PT I needed to put to use.
Question: how much capacitance do I need? I looked at other amps for guidance--notably the Trainwreck Rocket. The caps in that thing add up to 180 uF, which is over twice what you find in a 5F6A.
I'm planning to use a 5AR4 and preamp tubes similar to a Bassman. I would like a little sag.
I don't really know how people decide how much capacitance to use. It almost seems arbitrary. I know they have to be big enough to discharge slowly enough to kill the AC, but beyond that, it's very mysterious to me.
Capacitance for 4-EL84 Amp?
- The New Steve H
Relax. It's SUPPOSED to smoke a little.
Re: Capacitance for 4-EL84 Amp?
AFAIK the C max of the 5AR4 rectifier is 60uF. HTH.
I'll say what I've absorbed, without looking it up first, and then the smart kids can laugh.
Higher capacitance can mean "stiffer" bass, which I take to mean less sag. Possibly it will be harder to get your desired sag with lots of capacitance.
You can stress a tube recto with too much capacitance.
OK, that's all I remember.
- The New Steve H
I'm thinking I'll stick a total of 80 uF on this thing and see how it sounds. I can always glom extra caps on later.
Tubes are really crazy. Everything involves a guess or an empirical test.
