surfsup wrote:The 39/150k in parallel is 31k. Why didn't you just try a 33k like on the other side? (just curious)...
I didn't have a 31k and I did try 33k
  - I tried a lot of values, both in simulation and in real life. While the PI is clean, there's no problem - you have free choice of ratios. I played the amp for quite a while with 33k/47k and 39k/56k split loads (lowest value to B+) and while the cleans were good and the heavily distorted was OK, there was an ugly glitch between the two.
After a lot of testing, I think I tracked this down to the partial load PI being extremely unbalanced once the PI is over-driven - much more so than the standard PI. (FWIW my opinion is that the clean-to-mean transition is caused be the breakdown of the NFB loop as the output valves are driven into grid conduction. This causes the PI to be over-driven, hence its behaviour and headroom are key to the distorted sound - YMMV).
I could get a compromise of balance between clean and driven with the standard PI tail resistor (10k) - maybe 4% in each case, but the cleans had lost their 'jangle' and there was still this ugly glitch. I think this was because the lower level PI output clean became the higher one distorted (& vice versa), so there was a big change in PI behaviour at the onset of being over-driven. The only way I could find to minimise the change in PI balance between clean and driven was to increase the tail resistor and be quite picky about the split load values. From memory, the PI is balanced within about 2% clean & 4% driven, but the same output is the greater in each case, so there is only a small change between clean & over-driven behaviour of the PI.
I initially worked out the partial load ratios to try and replicate the behaviour of EL34 grids, but didn't re-calculate them after messing with the PI tail, with the result that there is a hair less drive than I intended, which means you can open the volume control up to 3:00, rather than ~1:00 If anyone feels like doing it, you could find some resistor values that give about 10% more output.
Note that the PI is now an ECC83 / 12AX7, rather than the 12AY7 in the original schematic.
You can see how I implemented it below. (The E'lytic-caps are ~10u and are between the bias voltage and ground, as I found that the bias voltage was wandering when the 6SN7 was driven to grid conduction, and generating a noise like a mosquito buzzing around your head! The big rotary switch is because I have an EL84 output stage built into the same chassis.)
passfan wrote:Tillydog are you british ? I just caught the 1000K which after a moment I realized was 1M.
Yes, in the UK, but the 1000k is just out of habit with LTspice (which is where I grabbed the schematic from)  because it recognises 1M as 1m - i.e. 0.001 ohm! It recognises 1meg OK, as long as I remember to type it.
This mod worked for me. I would be really interested to hear any feedback if anyone else tries it.
No guarantees
Andy
