PPIMV LOUD HUM
PPIMV LOUD HUM
Strange.....
100w 1959 circuit.
Lar/mar ppimv which I have installed many times.
With the bright and normal volumes on zero and the PPIMV on zero I get a loud hum. With the PPIMV ON 10 the hum goes away.
Any ideas?
100w 1959 circuit.
Any ideas?
Rockstah Amps: http://www.rockstahamps.com
Rockstah Amps Youtube: http://www.youtube.com/user/RockstahAmps
Builds and modification sound files: http://www.soundclick.com/rockstahplexitweaksandmods
Cliff Schecht
Re: PPIMV LOUD HUM
Sounds like the pot body is not shielding the internals at all. I had this problem recently on my Vibroverb build with the reverb pot, it would hum when turned down but would be hum free when maxed. The fix for me was adding one of those little washers with a long solder tab that went around the pot shaft (in between the pot and the amp on the inside) and soldered directly to the ground lug of the pot. Cleaned the hum right on up.rockstah wrote:Strange.....
100w 1959 circuit.
Any ideas?
How is the PPIMV pot grounded? Is the body of the pot grounded at a different location than the lugs of the pot?
Cliff Schecht - Circuit P.I.
Re: PPIMV LOUD HUM
I quote Cliff, but an internal picture would be useful.
Check pot grounding to chassis.
Re: PPIMV LOUD HUM
again, i have installed these many times with no issues. maybe its time to try another choke.
it just doesn't make sense as to why its loud on zero and gone on 10.
the added washer seems it would fix masters that are grounded to the chassis.
[IMG:785:689]http://i24.photobucket.com/albums/c44/m ... Logpot.gif[/img]
- Reeltarded
Re: PPIMV LOUD HUM
Nice!Gaz wrote:I thought you invented it
Re: PPIMV LOUD HUM
It has sense, if you have ripple on bias voltage, so a bias cap that's dry.
Re: PPIMV LOUD HUM
I would suspect a bad pot that isn't making good contact with the trace and it's "ground" tab.
Re: PPIMV LOUD HUM
i guess i will swap in new caps but they are new...hmmmroberto wrote:It has sense, if you have ripple on bias voltage, so a bias cap that's dry.
Re: PPIMV LOUD HUM
This master was developed over at Metroamp.Reeltarded wrote:Nice!Gaz wrote:I thought you invented it
When i was trying it inside a marshall, while looking for a better solution, (i didn't like the way the rich mod sounded) I came across it pouring through ken fisher data.
It was Larry that came along and added the safety resistors.
The name, Lar/Mar PPIMV was to have reference point to this improved master. Nothing more nothing less.
Now you know the rest of the story.
Re: PPIMV LOUD HUM
i swapped out the pot and checked all connections.Jana wrote:I would suspect a bad pot that isn't making good contact with the trace and it's "ground" tab.
Re: PPIMV LOUD HUM
Just out of curiosity, measure the bias voltage going to the power tubes at various settings of the pot. Measure at the grids of the power tubes to get the actual reading and not at the bias feed portion of the circuit.
Re: PPIMV LOUD HUM
did that. -41.89 dcv at all settings of the pot on all tube grids.Jana wrote:Just out of curiosity, measure the bias voltage going to the power tubes at various settings of the pot. Measure at the grids of the power tubes to get the actual reading and not at the bias feed portion of the circuit.
Re: PPIMV LOUD HUM
Does the hum diminish gradually from 0 to 10? Or is there a sudden drop when the wiper hits any resistance?
Re: PPIMV LOUD HUM
gradually as the volumes goes up to 10 where it goes away completely.Firestorm wrote:Does the hum diminish gradually from 0 to 10? Or is there a sudden drop when the wiper hits any resistance?
