New surfin' amp
tubeswell
New surfin' amp
Post by tubeswell »
Finished this last w/e - based on a BF amp with old flame reverb and 6G16 bias-vary trem wrapped in a tweed style chassis. Weighs a ton. Quite loud and surfy. Sounds good with my Jazzie.
NickC
Re: New surfin' amp
Post by NickC »
Nice! Really nice! 8)
tdvt
Re: New surfin' amp
Post by tdvt »
NICE!
Any sound clips yet ?
I've got a Hoffman version of that in the works; board's done, transformers just arrived & its also going in a tweed-style chassis w/2-12 cab.
Got to do all the chassis holes/drilling next.
Looking forward to getting it going, glad to hear you like yours.
Re: New surfin' amp
Another fine looking amp!
Re: New surfin' amp
I like the dress you bought for it!
Re: New surfin' amp
Reeltarded wrote:I like the dress you bought for it!
Yeah, gingham plaid? Very '60's! Nice job!
RevD
Re: New surfin' amp
Post by RevD »
Very cool, working in those tweed chassis's are a bit tight for fat fingered me (although this looks wider than say a deluxe for example), good job Man!
Regards,
Don
Cliff Schecht
Re: New surfin' amp
Post by Cliff Schecht »
Tubeswell this looks like something I built. Lots of "random" cap choices and really just using whatever I have on hand at the time. Then again nothing is ever truly random, I like to think of my cap choices more as fate (it was this caps fate to run across my hand at the time that I needed that value :lol:). FWIW I tend to use my (supposedly) aurally superior caps earlier on in an amp (first stage, tonestack) where the subtle differences I think have a larger influence over the final sound. Don't know if you do the same, just something that I got in the habit of doing for whatever reason.
Also do you prewire the PCB's before you install them or wire everything once the board is installed?
Cliff Schecht - Circuit P.I.
Zippy
Re: New surfin' amp
Post by Zippy »
What's that row of grommets at the far right (input) side of the circuit board?
Cliff Schecht
Re: New surfin' amp
Looks like either a ground "buss" or he ran a few test eyelets before starting the main ones :D.
tubeswell
Re: New surfin' amp
Post by tubeswell »
Zippy wrote:What's that row of grommets at the far right (input) side of the circuit board?
the ground buss for the pre-amp (goes to the input jack ground(s))
tubeswell
Re: New surfin' amp
Post by tubeswell »
Cliff Schecht wrote:Tubeswell this looks like something I built. Lots of "random" cap choices and really just using whatever I have on hand at the time. Then again nothing is ever truly random,
Yep - just grabbed what was on top of the stash/pile
Cliff Schecht wrote:Also do you prewire the PCB's before you install them or wire everything once the board is installed?
Populate the board, then wire the whole board in, then subsequently fix the bits that I should've got right the first time ;-)
