Yeah I was going to say, see if you can get some other lighting source instead of the Flourescents.
Try to minimize the noise sources before going crazy with power conditioners, which rarely work on noise.
In my experience, non of those surge/ spike protectors will do anything for noise riding on the house current.
You will have to spend huge $$$ to get something that will actually clean up the power.
Is your breaker box in the basement?
I would consider running a dedicated 20 amp service to where your guitar gear is and have a dedicated circuit for it.
You can actually build a line conditioner with large capacitors (1000uF or so) with smaller caps to take out higher frequency noise.
Even some type of choke inductors.
I would get a 1:1 isolation transformer of the correct rating and then run the filters after.
Line conditioner circuit.
[img:300:114]
http://justradios.com/source.gif[/img]
