Hi & Thanks to All,
@Lynxtrap :
I'd rather say that this is the tone of a "modern sounding amp, tight and controlled", exactly in the vein of a RIVERA M-60 or 30-12, just to mention the ones that I had in hands recently for service, but indeed it's not the tone of the MKI and IIA (B) Boogies, that I would qualify as "touch-sensitive"...
Unfortunately I do not have the gear and the time to devote to make such a
well-played and
excellent-sounding sample as yours +++ !
@anthony8i :
Lynxtrap is right : The Ceriatone is something like a "Dumble Kit" AFAIK, but I never had one in hands for the moment... So as Mr Santana seems to use now mainly Dumbles, it would be "the alternative kit", probably more versatile in tone than a MKI or IIA, but clearly not the same.
With the exception of the PCBs sold through a russian seller via eBay, I do not know the existence of a Boogie kit, but by experience, building a point-to-point handwired Boogie MKI is nonetheless possible. It would be more complicated with a dual-channel MKIIA, where unwanted interstage coupling may occur. Beware... designing and wiring tube amp knowledge is compulsory in any ways, because it is not a kit !
One trick about the MKIIA :
On most amps (and later Boogies like MKIIC, MKIII) the reverbered signal source is taken
after the channel switching. I mean : when clean channel = clean reverbered signal, when lead channel = overdriven reverbered signal.
On a MKIIA (and B, not C), the reverbered signal source is taken
before channel switching. I mean : clean, overdriven or boosted channel = always
clean reverbered signal.
Overdriven reverbered signal usually always lack of deepness, have blunt decay or sound weak and metallic, which makes it rather unpleasant sounding, at least to my taste, as I use always reverb (like Mr Santana on its early well-known works, by the way).
You may know that the reverb of the MKI and
for sure of the MKIIA is certainly one of the best-sounding : pure, smooth, even-sounding, non-metallic deepness and decay.
So when you play in lead mode on the MKIIA you still have that clean reverb... Huge difference in tone, trust me ! It would be the same as if you played a Princeton Reverb set to obtain an overdriven sound : you would have overdrive, some sustain and feedback and a clean deep reverb behind, not the common fuzzy metallic reverb sound usually heard...
The MKIIA and B are the only amps I know to have that distinctive reverb fearture, but of course, if you barely or never use reverb, it's way less important.
@xtian :
Greetings. Your amp build looks awesome. I see that you're a regular on Grailtone, but I'm glad you've joined us here, because I just sold my Mark IV, and won't be visiting Grailtone much.
In fact, there is not much technical forums dedicated to designing and building tube amps... Grailtone is not, but proved very usefull and kind for finding advices and infos about Boogies, and on my amp in particular. But when these guys front problems, they usually call or send their amps to Mesa, period... Not much technical, unfortunately.
These times, I am trying to save time for re-designing the smallest amp on my previous post pictures - a mini-Boogie MKIIA with 40 to 60W. Surprisingly, the trials I have made proved very successful, sounding big despite the compact size, but the problem is to enter all the stuff in a such small package : that needs accuracy and precision in the design of the chassis' layout, in order to avoid parasitic couplings, oscillations, vibrations... I am on it...
A+!
