octal preamp
octal preamp
Has anyone had experience using a 6SJ7 octal preamp tube?
Re: octal preamp
I've been wondering the same thing. I know Alessandro uses them and apparently with some success, but I've never had any experience with them myself. I'm very curious to hear anyone's thoughts.
Re: octal preamp
I built a hybrid amp that was a mix of the Moonlight power stage (6sl7 phase inverter and a 6sn7 dual triode running as a push-pull output) and an Octal Fatness pre that used a 6sj7.
Was kinda cool but I didnt fall in love with it and didnt have the patience to fully tweek it out so I rebuilt it with a 'wreck preamp and really did dig on the way that turned out.
The 6sj7 is a cool inexpensive way to play around with a pentode preamp tube. Here is a link to one of David Jones' schematics that uses the 6sj7:
http://www.diyguitarist.com/Schematics/ ... s-Full.jpg
and here's Dave's other schematics and such:
http://www.freewebs.com/jonesamps/jones ... matics.htm
Re: octal preamp
I love the sound of the 6SJ7. Having said that, it's hard to find one that isn't microphonic, I would also recommend running the 6SJ7 or 6SL7 on dc heaters to avoid some of the hum. I have an amp I just built using the 6SJ7 and 6SL7 for one channel and an Express preamp for the other channel. The Russian 6SJ7 and 6SL7 are pretty good tubes as long as you keep the gain under control to prevent squealing and oscillation. Oh yea, the power section of the amp is using a dual single ended EL34 configuration with fixed bias.andrew wrote:Has anyone had experience using a 6SJ7 octal preamp tube?
Here are some clips
This is just the Octal channel by it self. A little chickin pickin, Brad Paisley kind of tone with a Tele.
http://users.zoominternet.net/~jdhall/a ... le%202.mp3
Here is a clip of both the octal and Express channels combined.
http://users.zoominternet.net/~jdhall/a ... 20tele.mp3
funkmeblue
Re: octal preamp
I had bettet luck with the chinese 6n9p than the sovtek 6sl7.....
Re: octal preamp
Hmm, sounds a lot like Richie!UR12 wrote: Here are some clips
--mark h
Re: octal preamp
Yep, its Richie. He swears he's going to get Bud to do the next ones
Re: octal preamp
Mr. UR12, great clips! What power section set up is that? What is the trans voltage and OT? My single ended Rocket preamp-Adams SE power section is on hold due to a dead OT somehow. Until I get a new one I might want to build an octal after all! Thanks, Andrew
Re: octal preamp
Andrewandrew wrote:Mr. UR12, great clips! What power section set up is that? What is the trans voltage and OT? My single ended Rocket preamp-Adams SE power section is on hold due to a dead OT somehow. Until I get a new one I might want to build an octal after all! Thanks, Andrew
This amp was a group project. The power section is running 2 EL34 in parallel single ended. Voltage runs about 400v. The OT is a customed designed 2.5k SE airgapped tranny that we had Heyboer make special for us. There was nothing off the shelf that we could find to do the job. It is also running fixed bias instead of cathode bias and pumps out about 30w. The amp is still in the prototype/testing phases so I am sorry I am not at liberty to supply you with schematics.
Re: octal preamp
When it's finished will you publish the layout in Ampgarage?
Re: octal preamp
I'll see what I can do and if the group doesn't mind it would be fine with me.
- David Root
DC Heaters with Octal Preamp Tubes
I can second the comment about using DC heater supply on octal preamp tubes. I built a 4-6V6 amp with five 6SL7s as pre-s and PI and I finally put DC on all the heaters, (including the 6V6s, which probably wasn't necessary), but it killed the hum dead!
I think we are so used to the 9-pin 12A*7 series and related minature noval types, that have the humbucking heater connection "option", that it doesn't occur to use DC heaters on the older octals which don't have the humbucking wiring option, UNTIL you actually try it!
Alessandro uses octal pre-s because the bigger glass gives a more spacious tone. However, he also uses Black Gate power supply caps, which would have something to do with that too. But that's a whole different post!
Re: octal preamp
Sharp-cutoff pentode, Very good sounding amp Dana, you hook the 6SJ7 up as a pentode or a triode ?, My experience with octal's are bout the same, some are microphonic, some not so much, I just finished a very old Electromuse 1X12 combo for a Harp Man, Had 2 X 6SJ7's & 2 X 6V6's turned out very nice, I do know this, set up right, octal's are very touch sensitive to the Guitar, I have a great collection of octal tube's, if you need some and I have the # I'll donate some for this thread, I have a very large old tube collection, and what's sad I still have to buy a few here and there,
You just never got all ya need !
unklmickey
Re: 12SQ7
goodness no, Andrew.andrew wrote:Could I use a 12SQ7 in place of a 6SJ7? It's an old RCA.
they are entirely different types of tubes, even the heater connections are in the wrong places.
if you did that, you would almost certainly destroy things.
unk
