Hi,
I have some extra parts, and I'm thinking of putting a 5E3 build in a Valve Junior boxand chassis. I have a vibrolux OT and a 4 ohm cabinet.
I'm not really looking for it to be much louder than a stock 5E3, but I'm thinking that with a 6L6/5881 (or possibly EL34) type tube the amp may have a bit more extended highs and lows. I'm looking for a PT that would be 350V to 370V in the circuit, and be able to handle the higher current of the larger tubes.
Good PT for 5E3 type build with 5881?
Muttleyboy
Re: Good PT for 5E3 type build with 5881?
For cathode biased 5881s in a 5E3 type amp, to get about 360-380 volts on the plate, I would guess you'd want about 270-0-270 to 280-0-280 @150mA-180mA with SS rectification or around about 325-0-325 @150mA-180mA with a 5U4G for some sag. I'd suggest that the heater winding be rated about 4A (and a 3A rectifier winding for the 5U4). These are all fairly crude guesses and JM2CWMuttleyboy wrote:Hi,
I agree with Tubeswell. Look at a Hammond 270FX or 270HX power trannie. I use a 270FX with a cathode biased amp using 5881's.
With respect, 10thtx
- Lonely Raven
I think I might have one of those in storage I'd let go inexpensively. I don't have as much time or money to build the amps I bought transformers for. I'd rather finish the work I have now.10thTx wrote:I agree with Tubeswell. Look at a Hammond 270FX or 270HX power trannie. I use a 270FX with a cathode biased amp using 5881's.
If this is the power transformers you decide on, PM me and I'll see if I still have it tucked away somewhere.
Jack of all Trades,
Master of None
Master of None
Muttleyboy
Hi Tubeswell, Hi 10thtx,
Thanks for the replies... Yeah I forgot to say that I'm going to want some tube rectifier sag, and that I'm hoping to get around 350V with a 5Y3 and then experiment with other rectifiers for some higher voltages (under 400v).
I saw on the allen amps site that they have a PT for the Brown Sugar model which they rate as 320V and 180mA. The description goes on to say that in the circuit, it should be 410V with a gz34. I'm thinking that may be too much.
10thtx, with that hammond 270fx, are you using a tube rectifier and what is the B+ voltage in the circuit?
Thanks again,
-Chris.
Thanks again,
-Chris.
275vac X 1.2 (5V4 recitifier) = 325v estimated
275vac X 1.3 (GZ34 rectifier) = 350v estimated
275vac X 1.4 (solid state rectification) = 375v estimated
You can step up to a 272HX trannie for 300-0-300 & use a GZ34 for around 390v.
While Silvertone did it, you probably do not want to use a 5Y3 with 5881 or 6L6 tubes that are push/pull cathode biased.
Muttleyboy
Hey Thanks 10thTx,
That sounds like it should be the one.
