Mickey, you're obviously a Marshall guy
Asking which Dumble is the classic tone is rather like asking what a Plexi tone is.  There's many.
In general they are all very sensitive to your playing style and pick technique moreso than many other amps. Set up well, the notes should bloom into feedback even with a relatively clean tone. The HRM is a bit more gainy with a more modern feel than the non-HRM. The HRM clean sound is virtually unimaginable from a set of EL34's. It's the best of any amp I've played.
The real non-HRM Dumble I played was a very harmonically complex amp that was smooth yet extremely aggressive. None of these amps could be called forgiving. However, the HRM has way more gain than what most people imagine it to have, but it will remain clear and articulate and highlight any mistakes and playing flaws in a big neon sign !
The commnon denominator with all of the Dumbles circuits is the tweaking. Basically you have to tweak them to the playing style and guitar. Dumble made no two amps exactly the same, so getting all hung up about using exact make of parts for everything can be pointless.
There are a few critical areas where component selection is very important, there are also some pretty critical preamp plate voltages to aim for. But apart from that, he used pretty bog standard Fender trannys for the 6L6 models and off the shelf US made trannys from Magic Parts for the HRM's.  The feedback circuit should be designed for the trannies you use. The ref circuits on this site give you some reasonable starting values, but every one I've built I've had to tweak the feedback resistor (amongst many other things).
Looking at the amps you currently sell, this is very different (but I'm sure you know that already) and I'm sure you've built more complex ones before anyway. Relay selection, relay power supply and cable dress are all very critical if you want a noise free channel switcher. The grounding scheme is also critical, use Dumbles, don't even bother trying a Marshall or any other scheme, nothing else is anywhere near as effective. The HRM's require special attention in the relay area, many people have had popping problems. However they can be made dead silent with a little bit of thought. All the information can be found on this site. You sometimes just have to dig deep for it.
Good luck and enjoy your first build.
Just post any questions, several folks on here have a pretty deep understanding of these amps.
Kind Regards,
Alan Phillips
Carol-Ann Custom Amplification
