Pre-amp output grounding.
marcoloco961
Post by marcoloco961 »
Tried to grab a pre-amp output of off an amp directly after the tone stack out. It is a pretty decent signal strength for what I need but I have a huge grounding issue. It has nice tone but a nasty 60 or 120 Hz (guessing) hum coming from the amp I am using as the power amp. This amp has no issues and sounds great when not plugged into the pre-amp out of the other amp. The tube amp I am using for a pre is also quiet until I plug the two together.
Just for reference the amp I am using as a pre-amp is a 50 watt tube bass amp, and the amp I am using for the power section is a 350 watt Ampeg SS amp.
I am using shielded wire for the signal and took the ground from a spot closest to the jack. Should the ground be floating, or do I need to ground close to the OT outs on the other speaker jacks in the tube amp.
If I can whip this ground issue, I think I would be happy with the set-up.
TIA for any info or suggestions.
ChrisM
Re: Pre-amp output grounding.
Post by ChrisM »
Sounds like a ground loop issue to me.
marcoloco961
ChrisM wrote:Sounds like a ground loop issue to me.
That is what I had figured. Any way to avoid the loop between the two amps that you know of?
You can lift the ground of the power amplifier but it can be dangerous but if the amp you have your guitar plugged into is grounded then I think it would be OK.
NickC
Post by NickC »
You could try balanced interconnects between the pre and power amp.
http://www.dplay.com/dv/balance/balance.html#balance
jjman
Post by jjman »
Try lifting the ground (shield) on one end of the signal connector between the 2 amps.
marcoloco961
Thanks guys, I will try a few of these and see if it helps.
Will do them one at a time to see what works best, and then report back.
rdjones
Post by rdjones »
First and foremost before lifting any grounds, make sure both amps are plugged into the same grounded outlet.
Is the tube amp's AC wired for modern 3 prong safety grounding ?
rd
NickC
Post by NickC »
Maybe not a permanent solution, but handy to have in the gig bag (and might help trouble-shoot the problem at hand):
http://www.ebtechaudio.com/llsdes.html
Or maybe try the Hum X.
marcoloco961
rdjones wrote:First and foremost before lifting any grounds, make sure both amps are plugged into the same grounded outlet.
rd
Yes, the tube amp has a 3 wire properly grounded chord. Neither amp has any issues with the noise until I hook the line between them then I get a loop.
At first I used a small chord that was a TRS chord converted to a TS chord. It has the two wires and the shield, kinda like the balanced idea. Noise was audible but not horrible until turned up over half. Then I tried a speaker cable, and it was much worse. Obviously the speaker cable was a totally improper choice for a signal.
Gonna try making a balanced chord like Nick suggested. If it still is there, I will lift on end of the shielding from the ground and see what happens. Thanks again for the great input everyone.
marcoloco961
Structo wrote:Or maybe try the Hum X.
That was looking like the way to go until I saw the Price...............71 dollars????
Anyone got a schematic??? :twisted:
marcoloco961
Thanks all, I ended up putting a TRS jack on the pre out and sending the signal out the Tip and the ground through the ring. I left the shield unconnected on this end. On the power side I connected the signal to the tip and the ground from the pre amp and the shield to the sleeve. This didn't completely kill the hum, but cut it about 80% or better. It is now livable and can be used without an issue.
Once again, I sincerely appreciate the advice.
